What will be the image distance when he reverses the mirror ?
  • Thread starter Thread starter cclement524
    Image Mirror
The discussion revolves around calculating the image distance when a man reverses a double-sided spherical mirror from convex to concave while maintaining a distance of 47.4 cm from his face. The initial calculations indicate that the focal length for the convex side is positive, while for the concave side, it should be negative. The user struggles with sign conventions and the resulting image distance, which is calculated to be approximately -8.53 cm for the concave mirror. Suggestions include ensuring the correct application of sign conventions for object and focal distances, as well as verifying calculations for accuracy. The overall goal is to achieve a correct understanding of the mirror formula and magnification in both configurations.
cclement524
A man holds a double-sided spherical mirror so that he is looking directly into its convex surface, 47.4 cm from his face. The magnification of the image of his face is +0.18. What will be the image distance when he reverses the mirror (looking into its concave surface), maintaining the same distance between the mirror and his face? Be sure to include the algebraic sign (+ or −) with your answer.
mirror formula> 1/f = 1/v + 1/u
f = vu/(v+u)
v> image, u>object, f> focal
m = magnification = - v/u
1/f = 1/v + 1/u
v = fu/(u-f)
f = vu/(v+u)
convex> u = - 47.4,
m = magnification = - v/u = - v/(-47.4) = +0.18
v = 8.532
f = 8.532*47.4/8.532-47.4 = 7.23
it has to be assumed that radius of curvature (R = 2f) is same
concave>
f = - 7.23
u = - 47.4 (same)
1/f = 1/v + 1/u
v = fu/(u-f)
v = concave = (-7.23)(-47.4)/[- 47.4+ 7.23]
v = concave = - 8.53129cm
m = - 8.531 /47.4 = - 0.17998
I am getting the wrong answer with the wrong sign somehow, but I don't know where I went wrong. Any help would be greatly appreciated. Thank you!
By convention, object distance should always be positive for a real object. The focal length should be negative for a convex mirror and positive for a concave one. If you flip all your signs around, you'll get the right answer.
I am still getting a decimal answer, but the answer is somewhere around 10. Is there anything else I should be doing differently?
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
