What's the difference between fine and coarse measurement?
Fine measurement and coarse measurement refer to different frequencies used in distance measurement technology, specifically in the Kern DM500 distance meter. The fine measurement frequency of 14.985400 MHz provides high accuracy for short distances, while the coarse measurement frequency of 149.854 kHz allows for longer distance estimation with less precision. The relationship between the two frequencies enables the device to first determine a general location using the coarse measurement and then refine that measurement with the fine measurement. This method relies on phase shifts of modulated light signals to calculate distances accurately. Understanding these distinctions is crucial for effectively utilizing electronic distance measurement tools.
gilnaz
Would anybody pleas tell me what's the difference between fine and coarse measurement? I am reading a paper named "Electronic distance measurement-An introduction" in which fine measurement and coarse measurement is mentioned. here is the exact paragraph:
"The transmitter includes a master oscillator, a digital divider (1: 100), a modulator and two infrared emitting diodes. The master oscillator (RTXO) produces the fine measurement frequency of 14.985400 MHz (- 15 MHz) corresponding to a unit length of 10 m. The coarse measurement frequency of 149.854 kHz (-150 kHz) is then derived by the divider."
for-mentioned paragraph is an explanation about a Kern DM500 distance meter and describing what's going on inside.
Any explanation in this regard is appreciated.
Regards,Gilnaz
I can think of two wildly different speculations.
The Kern manual is pay only. Perhaps you should contact the company.
Generally these things use phase shifts of reflected modulated light. Compare the transmitted signal with the phase of the reflected signal to determine the distance.
If one uses wavelengths to measure distance, the a long wavelength (low frequency) will measure long distances with less accuracy and the short wavelength is used to get better accuracy.
If you only use the the short wavelength, you could be off by a full wavelength. So the coarse/long wavelength tells you about where you are (within a short wavelength) and then the short wavelength makes the final measurement.
This is predicated on the concept that the precision of the measurement of each wavelength is pretty much a constant "parts-per-wavelength". So if the short wavelength is 1/100th of the long wavelength, the short wavelength will measure 100 times more accurately (and the long wavelength will be able to measure 100 times longer distances without being multiple wavelengths).
That was my first assumption. Then I got to thinking. What is this thing?
My initial perusal was that it's a range finder for game hunting. (Not paramilitary use, that would be illegal I think.). What if the coarse measure was for large objects, let's say "deer". (Not AFVs, that would be illegal.) Then the fine measurement could be for duck hunting.
This explanation isn't nearly as convincing as yours, but I couldn't rule it out without reading the costly manual. Of course I could be wrong about what this thing even is. Once again, a manual would be helpful. But while I'm willing to generously donate my time, I'm a tight fisted bastard.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
