Understanding Tensor Components: The Role of Index Order in Vector Spaces
  • Thread starter Thread starter quasar987
    Difference
quasar987
Say V is a vector space with base {e_i}, V* is it's dual with dual basis {e^i}. If someone says that T^i_{ \ j} are the components of a tensor, then I know this means that the actual tensor is
\mathbf{T}=T^i_{ \ j}e_i\otimes e^j
The order of the indices of the components of T indicates on which set is T acting. In this case, V* x V. Were the components T_j^{ \ i}, T would have acted on V x V*.
Now my question.
If \Gamma is a function from vector spaces V to W of respective bases {e_i} and {\tilde{e}_i}, and if we define the components of \Gamma as the numbers \Gamma_i^{ \ j} such that
\Gamma(e_i)=\Gamma_i^{ \ j}\tilde{e}_j[/itex],<br /> <br /> is there a meaning to the order of the indiced, or could I have just as well noted the coefficients as \Gamma^{j}_{ \ i}?<br /> <br /> Thanks.
Hi, quasar987, have you looked at Geroch, Geometry of Physics or Nakayama, Geometry, Topology and Physics? These should answer your questions.
Chris Hillman said:
Hi, quasar987, have you looked at Geroch, Geometry of Physics ...
Frankel? :smile:
George Jones said:
Frankel? :smile:
Presumably, although Geroch's Mathematical Physics, if I recall correctly, also discusses this.
Nakahara, maybe ? :rolleyes:
Daniel.
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
