Whats wrong with this free energy experiment
The discussion centers around an experiment involving a balance beam designed to test the effects of gravity on movement without lowering the center of mass. The experimenter claims to have achieved a balance with the center of mass at the axis, suggesting that it can level in any position, contrary to established physics. Critics argue that the experiment is based on misunderstandings of physics principles and emphasize the importance of clear communication in scientific discussions. The experimenter insists on the validity of their findings and invites others to replicate the experiment, expressing frustration with the perceived rigidity of accepted scientific knowledge. The thread highlights a tension between experimental claims and established physics, with calls for clearer explanations and reproducibility.
eosphorus
my objective was that gravity caused movement in an object without lowering the center of mass
i built a balance that has the center of gravity in the axe:
i used a 60 cm long 1 cm thick wood beam, i put a nail in the middle as an axe,
i put 100 grams of plastiline in each end of the beam
first try the CoM was lower than the axe what would be noticed because turning upside down the beam it wouldn level
the way to make sure the CoM is in the axe is by trying the balance normal and upside down
ive noticed it even has a period which by the way i was given here and deppends on the mass and length of the beam not how low the CoM is from the axe as is the case of a pendulum
my next step is freezing the plastiline to make sure the CoM is not lowered by the weight
anny suggestion of what I am doing wrong or how this is posible?
What's the obsession with "free energy"? Every single one of your examples so far--the yo-yo, the lop-sided balance, the tetherball--has been shown to have been based on a misunderstanding of the physics involved. What makes you think that your balance is any different?
As usual, it's unclear what you are trying to accomplish. Note: If a rigid body has its center of mass exactly at the axis of rotation that supports it, then it will be stable in any position.
physics has always been far to describe how nature works there are always corrections, if it wasnt this way the Earth would still be said to be flat
im not claiming on ideas I am claiming on facts, i built a balance that levels with the center of mass in the axe, anybody can reproduce this
you say it won't level because physics say so, i disagree because I've experimented it
now if physics say one thing and experimental data say the opposite what's the conclusion
my conclusion is that as long as people believes blindly what they are taught mothers will see their kids starve to death(from here comes my obsesion with free energy) because things are too complex to be changed then
you say an object with the center of mass in the axe won't move, I've experimented a balance with the center of mass in the axe will move and i welcome anybody to reproduce the experiment
just my two cents
What is your native language? some of what you say does not make sense - when you say axe, do you mean axes? (x.y,z axes?).
I agree with you that it is not good to blindly accept all of physics, but you need to explain yourself more clearly. Do not forget that it is *possible* that you overlooked something in your experiment. Try and explain the experiment fully and see what people say about the physics...
You have no ability to say that when you are ignorant of physics. You should follow your own advice and stop making judgement calls on things you haven't not understood in the first place.
And please don't ask us to EXPLAIN what you did when you cannot even state what you are doing in a clear and coherent manner. This has been an ongoing pattern of your post and I have seen zero improvement at all. This has the earmark of going down the path of all your other posts, i.e. nowhere.
Please refrain from starting one of these types of threads again.
Zz.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
