Wheel calculations (Power, torque, etc.)
4 replies · 4K views · last reply
Jared94
Hi there, I've forgotten how to solve these problems, eg:
If I've got two shafts, two wheels per shaft meaning four wheels in total, each wheel is 60 mm in diameter, and the power consumed by the system in providing a constant horizontal velocity of 0.15 m/s is 200W, what is the torque in each wheel? The wheels are rubber coated, and the wheels are acting upon a steel surface (take coefficient of friction to be 0.7).
This is how I've solved the problem:
Power = Torque x angular velocity
w = v / r = 0.15 / 0.030 = 5 rad/s
Torque = P / w = 200 / 5 = 40 Nm
Now since there are 4 wheels (instead of just 1 wheel) AND two shafts with two wheels in each shaft, how do I interpret this torque of 40 Nm? Is the force per wheel just force = Power / velocity or is this force divided amonst the 4 wheels?
With the friction, since the system is moving at a constant speed of 0.15 m/s, will the thrust force equal the frictional forces? The force here doesn't equal the force calculated via the torque of 40 Nm, is this because of a transmission efficiency?
Thanks in advance, really annoying how I still haven't grasped these basic concepts (I'm studying Mechatronics engineering at uni)
Yes, the force is divided amonst the 4 wheels. Yes, the thrust force equals the frictional forces. The thrust force equals the force calculated using a torque of 10 Nm at each wheel.
If this is a real system, it may be worth pointing out that, when going round a curve, the speeds of the wheels need to be different, to avoid slipping and power loss. In practical systems, it is common practice to use a (three) differential(s)
At constant speed the sum of all forces equals zero. That comes from Newtons F = m*a. So yes the magnitude of the thrust should equal friction (if there are no other losses).
However..
How are you calculating the frictional force? It's not just F = μ*N. That would be the maximum force before the wheels start to slip. The actual frictional force will be lower (and hard to calculate - unless you calculate it from the thrust).
This is only true if the wheels are all going at the same speed and in a practical situation you can't be sure of that.
The "friction" forces in this problem will not involve any loss of power - it could be a rack and pinion system if there is no slippage.
That value F is the limiting friction force and the actual value could be anything less than μ*N, I think.
