When do quadratic polynomials generate the same ideal?
Mr Davis 97
When do two quadratic polynomials in ##\mathbb{Z}_3 [x]## generate the same ideal?
I feel like they generate the same ideal only when they have the same coefficients, but am not sure how to show this.
It's not necessary for your question, as you only asked about principal ideals. Nevertheless, is ##\mathbb{Z}_3[x]## a principle ideal domain?
Now to approach your question. As always, write down what is given, namely two ideals ##I=\langle p(x) \rangle## and ##J=\langle q(x)\rangle## with polynomials ##p(x),q(x)\in \mathbb{Z}_3[x]## and ##I=J##. The latter means ##p(x) \in J## and ##q(x) \in I##. What can you conclude from this?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
