When to use which dimensionless number
  • Context: Undergrad
  • Thread starter Thread starter member 428835
114 replies · 11K views
joshmccraney said:
Would the sides be ##\sqrt{g_{\theta \theta}}|_zd\theta##, ##\sqrt{g_{\theta \theta}}|_{z+dz}d\theta##, ##\sqrt{g_{zz}}|_\theta dz ##, ##\sqrt{g_{zz}}|_{\theta+d\theta}dz##?
Josh! You're the man! Excellent.
Now we are ready to do a force balance on our little window. In terms of the unit normal u's, what are the in plane tensile forces due to surface tension on the 4 edges of our window (recall that surface tension acts normal to the sides of our window)? (There is also a pressure force acting perpendicular to our window that we'll get to soon)
Thanks!
I think they would be $$\sigma \sqrt{g_{\theta \theta}}|_zd\theta\, \hat u^z\\
\sigma\sqrt{g_{\theta \theta}}|_{z+dz}d\theta\, \hat u^z\\
\sigma\sqrt{g_{zz}}|_\theta dz\, \hat u^\theta \\
\sigma\sqrt{g_{zz}}|_{\theta+d\theta}dz\, \hat u^\theta$$
joshmccraney said:
Thanks!I think they would be $$\sigma \sqrt{g_{\theta \theta}}|_zd\theta\, \hat u^z\\
Good, except that the ones at evaluated z and theta should be in the negative u directions. Now substitute your equations for the u's into these equations. What do you get?
Given the equations for the differential position vectors along the edges of the window, can you write a vector equation for the area of the window, including the normal vector to the window?
$$\left.-\sigma \sqrt{g_{\theta \theta}}d\theta\, \frac{g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta}{\sqrt{g_{\theta \theta}}\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right|_z = \left.-\sigma d\theta\, \frac{g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta}{\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right|_z\\
\left.\sigma\sqrt{g_{\theta \theta}}d\theta\, \frac{g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta}{\sqrt{g_{\theta \theta}}\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right|_{z+dz} = \left.\sigma d\theta\, \frac{g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta}{\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right|_{z+dz}\\
-\left.\sigma\sqrt{g_{zz}} dz\, \frac{g_{zz}\hat{a}_\theta - g_{\theta z}\hat{a}_z} {\sqrt{g_{zz}}\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}} \right|_{\theta} = -\left.\sigma dz\, \frac{g_{zz}\hat{a}_\theta - g_{\theta z}\hat{a}_z} {\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}} \right|_{\theta}\\
\left.\sigma\sqrt{g_{zz}} dz\, \frac{g_{zz}\hat{a}_\theta - g_{\theta z}\hat{a}_z} {\sqrt{g_{zz}}\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}} \right|_{\theta+d\theta} = \left.\sigma dz\, \frac{g_{zz}\hat{a}_\theta - g_{\theta z}\hat{a}_z} {\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}} \right|_{\theta+d\theta}$$
I think this would be
$$||\sqrt{g_{\theta \theta}}|_zd\theta\, \hat u^z \times \sqrt{g_{zz}}|_\theta dz\, \hat u^\theta|| \hat u^z \times \hat u^\theta = \sqrt{g_{\theta \theta}}|_zd\theta\cdot \sqrt{g_{zz}}|_\theta dz \, \hat u^z \times \hat u^\theta$$
It's much simpler than this. The area of the would be ##\hat{a}_{\theta}\times \hat{a}_z d\theta dz##. So the pressure force acting on the window from inside to outside would be ##p\hat{a}_{\theta}\times \hat{a}_z d\theta dz##, where p is the gauge pressure inside the fluid at the interface.
Of course, makes sense! I'm with you. So we've accounted for surface tension and pressure.
Are you saying there are other forces acting on our window?
Well, we're ignoring gravity. Viscous forces though from the side walls, what do you think?
I think that the interface has no mass, so that the gravitational force on the window is zero. The viscous contribution to the normal stress at the interface, when lumped in with the pressure (the shear stress is, of course, zero) might contribute a little, and we should consider that later (although I don't think it would be important). It should be neglected for now.
I'm with you, and agree with everything you've said so far!
OK. Please write down the force balance on the window, and divide by dtheta and dz. What do you get?
\left.\sigma d\theta\, \frac{g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta}{\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right|_{z+dz} \left.-\sigma d\theta\, \frac{g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta}{\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right|_z+
\left.\sigma dz\, \frac{g_{zz}\hat{a}_\theta - g_{\theta z}\hat{a}_z} {\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}} \right|_{\theta+d\theta}-\left.\sigma dz\, \frac{g_{zz}\hat{a}_\theta - g_{\theta z}\hat{a}_z} {\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}} \right|_{\theta}+
p\hat{a}_{\theta}\times \hat{a}_z d\theta dz = \vec 0\\
\frac{\partial}{\partial z}\left(\sigma \frac{g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta}{\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right)+
\frac{\partial}{\partial \theta}\left(\sigma \frac{g_{zz}\hat{a}_\theta - g_{\theta z}\hat{a}_z} {\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}} \right)+
p\hat{a}_{\theta}\times \hat{a}_z = \vec 0
where the rhs is 0 since the membrane does not have any mass. Something doesn't seem right though: the pressure term is the only term that is normal to the surface. If my work above is correct, then there would not be anything to balance it, implying ##p=0##. What do you think?
You can factor out the ##\sigma## from the derivatives. Regarding your question, the spatial derivatives of the coordinate basis vectors ##\hat{a}_{\theta}## and ##\hat{a}_z## along the surface have components normal to the surface. This is what the pressure has to balance.
In anticipation of what we do next, what is the magnitude of the vector ##\hat{a}_{\theta}\times \hat{a}_z##?
From your previous post we have $$\hat{a}_\theta=\frac{\partial R}{\partial \theta}\hat{r}+R\hat{\theta}\tag{3a}$$and$$\hat{a}_z=\frac{\partial R}{\partial z}\hat{r}+\hat{z}\tag{3b}\implies \\
\hat{a}_\theta \times \hat{a}_z = \left( \frac{\partial R}{\partial \theta}\hat{r}+R\hat{\theta} \right) \times \left( \frac{\partial R}{\partial z}\hat{r}+\hat{z} \right)\\
=-R \frac{\partial R}{\partial z}\hat z-\frac{\partial R}{\partial \theta}\hat \theta+R\hat r \implies\\
||\hat{a}_\theta \times \hat{a}_z|| = \sqrt{\left( R \frac{\partial R}{\partial z} \right)^2+\left( \frac{\partial R}{\partial \theta} \right)^2+R^2}$$
Geometrically this would be the area of a window along the surface. Is this what you're looking for?
It's also equal to ##\sqrt{g_{zz}g_{\theta \theta}-g_{\theta z}^2}##. Can you show this?
I don't think so. I know we've seen that show up a bunch in the denominators. It also looks like a Jacobian, which relates transformed area. How would you show it, or do you have any suggestions on how to start me out?
Here's a hint. The cross product of two vectors is equal to the magnitudes of the two vectors times the sine of the angle between them. The cosine of the angle between two vectors is equal to their dot product divided by the magnitudes of the two vectors. sin^2=1-cos^2
Beautiful. We have $$|\hat a_\theta \times \hat a_z| = |\hat a_\theta|| \hat a_z|\sin\theta\\
= |\hat a_\theta|| \hat a_z|\sqrt{1-\cos^2\theta}\\
=|\hat a_\theta|| \hat a_z|\sqrt{1-\left(\frac{\hat a_\theta\cdot\hat a_z}{|\hat a_\theta|| \hat a_z|}\right)^2}\\
=\sqrt{(|\hat a_\theta|| \hat a_z|)^2-(\hat a_\theta\cdot \hat a_z)^2}\\
=\sqrt{\sqrt{\hat a_\theta\cdot\hat a_\theta}^2\sqrt{\hat a_z\cdot\hat a_z}^2-(\hat a_\theta\cdot \hat a_z)^2}\\
=\sqrt{g_{\theta\theta}g_{zz}-g_{\theta z}^2}$$
OK. So, now going back to post #72, we have:
$$\sigma \frac{\partial}{\partial z}\left(\frac{g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta}{\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right)+
\sigma \frac{\partial}{\partial \theta}\left( \frac{g_{zz}\hat{a}_\theta - g_{\theta z}\hat{a}_z} {\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}} \right)+
p\hat{N}= \hat{0}$$where ##\hat{N}=\hat{a}_{\theta}\times \hat{a}_z##. The next step is to determine the pressure p by dotting the equation with ##\hat{N}## to obtain:
$$\sigma \hat{N}\centerdot \frac{\partial}{\partial z}\left(\frac{g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta}{\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right)+
\sigma \hat{N}\centerdot \frac{\partial}{\partial \theta}\left( \frac{g_{zz}\hat{a}_\theta - g_{\theta z}\hat{a}_z} {\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}} \right)+
p(g_{zz}g_{\theta\theta}-g_{\theta z}^2)= 0$$
See if you can show that this is the same as:
$$\sigma \left(\frac{g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta}{\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right)\centerdot \frac{\partial \hat{N}}{\partial z}+
\sigma \left( \frac{g_{zz}\hat{a}_\theta - g_{\theta z}\hat{a}_z} {\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}} \right)\centerdot \frac{\partial \hat{N}}{\partial \theta}+
I have no clue how you did this. What I'm thinking, though it doesn't seem applicable here, is if you rotate a vector ##\vec a## by a given amount and dot it with ##\vec b## it will be the same as if you rotate ##\vec b## by the given amount and dot it with ##\vec a##. But the derivatives aren't rotations. Honestly, to me this looks like dark magic.
From the second to last equation in post 79, I'll consider the far left term (dropping the constant ##\sigma##). The product rule implies
$$\frac{\partial \hat{N}}{\partial z} \centerdot \left(\frac{g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta}{\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right)=\frac{\partial}{\partial z}\left[\hat{N}\centerdot\left(\frac{g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta}{\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right)\right] -\hat{N}\centerdot \frac{\partial}{\partial z}\left(\frac{g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta}{\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right)$$
By the definition of ##\hat N## we have
$$\hat{N}\centerdot\left(\frac{g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta}{\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right) = (\hat a_\theta \times \hat a_z)\centerdot\left(\frac{g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta}{\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right)\\
=\left(\frac{g_{\theta\theta} (\hat a_\theta \times \hat a_z)\centerdot \hat a_z-g_{\theta z}(\hat a_\theta \times \hat a_z)\centerdot\hat a_\theta}{\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right).
Notice ## (\hat a_\theta \times \hat a_z)\centerdot \hat a_z = 0## and ##(\hat a_\theta \times \hat a_z)\centerdot\hat a_\theta = 0## since the dot product of two orthogonal vectors is zero. Thus the product inside the ##z## derivative from the first equation is zero, and we are left with
$$\frac{\partial \hat{N}}{\partial z} \centerdot \left(\frac{g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta}{\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right)= -\hat{N}\centerdot \frac{\partial}{\partial z}\left(\frac{g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta}{\sqrt{g_{zz}g_{\theta\theta}-g_{\theta z}^2}}\right)
Then I agree with your final equation in post 79 except that I think the two ##\sigma## terms are off by a sign. What do you think?
I don't think so, but we can check that later. So, from all this, if you do all the arithmetic, what equation do you get for the pressure p? We can compare notes.
I get (using the negative result I got) $$p = \frac{\sigma}{\left(g_{zz}g_{\theta\theta}-g_{\theta z}^2\right)^{3/2}} \left[ \left(g_{\theta\theta} \hat a_z-g_{\theta z}\hat a_\theta\right)\centerdot \frac{\partial \hat{N}}{\partial z}+
\left( g_{zz}\hat{a}_\theta - g_{\theta z}\hat{a}_z \right)\centerdot \frac{\partial \hat{N}}{\partial \theta}\right]
Nothing special here except simple algebra.
I meant to flesh out N, and do the dot products.
hahahahhaha I thought so! To be clear, we're talking about taking the coordinates back into ##z## and ##r##, right? I'll wait to crunch the numbers until you confirm. I know sometimes you have tricks up your sleeve.
I'll try to write out my result so we can compare.
OK, here's what I got for the pressure (if I did the arithmetic correctly). I corrected the sign error that you pointed out. Please check my results:
$$p=\frac{1}{R\left[1+\left[\frac{\partial R}{\partial z}\right)^2+\left(\frac{1}{R}\frac{\partial R}{\partial \theta}\right)^2\right]^{1/2}}-\frac{\left[1+\left(\frac{1}{R}\frac{\partial R}{\partial \theta}\right)^2\right]\frac{\partial^2 R}{\partial z^2}-2\frac{\partial R}{\partial z}\left(\frac{1}{R}\frac{\partial R}{\partial \theta}\right)\frac{1}{R}\frac{\partial ^2R}{\partial \theta \partial z}+\left[1+\left(\frac{\partial R}{\partial z}\right)\right]^2\frac{1}{R^2}\frac{\partial^2R}{\partial \theta^2}-\frac{1}{R}\left(\frac{1}{R}\frac{\partial R}{\partial \theta}\right)^2}{\left[1+\left[\frac{\partial R}{\partial z}\right)^2+\left(\frac{1}{R}\frac{\partial R}{\partial \theta}\right)^2\right]^{3/2}}$$
Hmmmm I'm not getting exactly this. Did you compute this result in Mathematica? If so I can send you my notebook. I plugged your result and mine in Mathematica and I am not getting zero when fully simplifying the difference of them both.
If you have Mathematica, let me know and I'll send you my notebook. If you don't have Mathematica, can we agree on the following components:
where ##N_z = \partial_z\hat N## and ##N_\theta = \partial_\theta\hat N##. Note vectors are denoted as ##\{a,b,c\} \equiv a\hat r + b\hat \theta + c\hat z##. Everything else is self explanatory I think.
If you have Mathematica, let me know and I'll send you my notebook. If you don't have Mathematica, can we agree on the following components:View attachment 220353
I confirm all those components.
