Where does the energy go when two out of phase signals are added?
The discussion centers on a solar energy system where an inverter was incorrectly installed, leading to a significant increase in recorded energy consumption. After the inverter was fixed, the user questioned where the additional energy went, as it was not consumed or dissipated as heat. The conversation explores the implications of adding out-of-phase signals, with an analogy of lasers canceling each other out. It is suggested that the inverter's incorrect wiring may have caused metering issues, potentially recording energy that wasn't actually consumed. Ultimately, the user seeks clarity on energy accounting in solar systems and the effects of phase misalignment.
steve wall
I have a solar energy system at my home. It basically uses an inverter that converts DC from the solar panels to AC that is phase-locked to the service from our electric company, then adds the two together to feed the home. There are two meters – one to measure the energy produced from solar, and one to measure the energy we buy from the electric company. A separate system measures our total home consumption.
Last March, the inverter failed and was replaced. After the replacement, I noticed the total consumption increased by as much as a factor of two, and complained. After a service call they told me that they had wired the new inverter backwards, but that it was now fixed. That made sense to me – hooking up the inverter backward would have meant the solar was subtracting from the paid service. Anyway, the consumption went back to normal, but the additional consumption was recorded by the service meter and I had to pay for it.
My question is, where did the additional energy go? We didn’t consume it, and nothing got burning hot. Or, in more general terms, when you add two signals out of phase and thus cancel them, where does the energy go? For example, if I were able to align two lasers (same wavelength and perfectly coherent) so that the electric fields canceled each other, would the light disappear? Would the lasers stop consuming power? Would they burn each other out?
If it was wired backwards I'm pretty sure the inverter would just shut down. So your consumption probably doubled because your panels wern't generating any electricty NOT because they were somehow feeding it in out of phase.
No, according to its production meter it was producing at about the same rate as always.
Do your solar panels put out enough power to reduce your consumption from the grid by 50%?
Only other thing I can think of is some kind of metering issue. If they connected the solar panels to the wrong side of your consumption meter that might explain it.
Drakkith: Yes, on a clear summer day we generate ~ 30 kWh, in the winter ~ 20 kWh. Our consumption varies from 15 to 40 kWh depending mostly on how much we use the air conditioning.
CWatters: Thanks for the thoughts.
Thread ''splain the hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
