Which Field of Research should be chosen in Mechanical Engineering
Choosing a research area in Mechanical Engineering for a PhD requires a genuine interest and passion for the subject. Starting a PhD without a clear focus may lead to challenges, as a strong fascination with a specific field is crucial. Participants emphasize that personal interest should guide the decision, rather than solely market considerations. Ultimately, the individual must reflect on what excites them most in the discipline. A successful PhD journey hinges on aligning personal interests with research topics.
go2saqi
Dear Fellows
I am just going to start my PhD in Mechanical Engineering. Can you people suggest me, which area should I choose? That will be interesting and challenging...
Any Suggestions PLEASE...
Saqib.
I might suggest that you made a mistake starting a PhD without an interest in any particular research area.
my brother, i have mathematical background, i have a very strong interest... and i think i can do it... I just want to get an idea of the market... finally i will choose mine... just suggestion.
That isn't all you need for a PhD in engineering. You need to have a passion for your field. If you don't have any idea which research branch fascinates you, then you shouldn't be getting a PhD at this time.
So the question you should be asking is which branch of research do you find most fascinating?
yes this is what i mean...
Well we can't answer that for you. Only you know what you consider fascinating.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
