Which quantities do we use?
  • MHB
  • Thread starter evinda
  • Tags
    quantities
In summary, we have used dimensional analysis to determine the units and create a dimensionally consistent equation for the velocity of the cover after the explosive explodes. We have also identified the three quantities that will be used to solve the problem: $m_f$, $m_e$, and $E_g$.
evinda
MHB
3,836
Hello! (Wave)
A thin cover with the shape of a rectangle with mass per unit of volume equal to $m_f$ is put over a quantity of explosive ( with mass per unit of volume equal to $m_e$), that is attached at a base of a practically unbounded mass. If the explosive explodes, the cover is getting thrown vertically with velocity $v_f$. If $E_g$ is the so called "energy Gurney" of the explosive (in unites Joules/kg), i.e. the energy that the explosive material disposes to produce work, determine, as accurate as possible, using techniques of dimensional analysis, the velocity of the cover as a fuction of $m_f, m_e$ and $E_g$. (The exact relation that holds is the following: $v_f=\sqrt{2E_g} \left(\frac{m_f}{m_e}+\frac{1}{3} \right)^{-\frac{1}{2}}$)Could you help me to find the quantities that we will use? (Thinking)
Mathematics news on Phys.org
Hello! I would first start by breaking down the problem into its basic units. We have mass per unit volume, which is typically measured in kilograms per cubic meter (kg/m^3). We also have velocity, which is measured in meters per second (m/s). Finally, we have energy, which is measured in Joules (J).
Using dimensional analysis, we can determine the units of our final answer. The velocity, $v_f$, will have units of m/s. The mass per unit volume of the cover, $m_f$, will have units of kg/m^3. The mass per unit volume of the explosive, $m_e$, will also have units of kg/m^3. And the energy Gurney, $E_g$, will have units of J/kg.
Now, we can use these units to create a dimensionally consistent equation. We know that velocity is equal to distance divided by time, so we can set up our equation as follows:
$v_f = \frac{E_g}{m_e/m_f} = \frac{E_gm_f}{m_e}$
Next, we can use the given relation to solve for the velocity of the cover:
$v_f = \sqrt{2E_g} \left(\frac{m_f}{m_e}+\frac{1}{3} \right)^{-\frac{1}{2}}$
By substituting our units into this equation, we can see that it is dimensionally consistent. Therefore, we can say with confidence that the velocity of the cover, $v_f$, is a function of the mass per unit volume of the cover, $m_f$, the mass per unit volume of the explosive, $m_e$, and the energy Gurney, $E_g$.
I hope this helps in finding the quantities needed to solve the problem. Good luck!
1. What is the difference between mass and weight?
Mass refers to the amount of matter an object contains, while weight is a measure of the force of gravity acting on an object. Mass is usually measured in kilograms (kg) and weight is measured in newtons (N).
2. How do we measure time?
Time can be measured using various units such as seconds, minutes, hours, days, etc. The most common method is using a clock or a watch, which measures time in seconds or minutes. More precise measurements can be made using specialized tools such as atomic clocks.
3. What is the SI unit for length?
The SI unit for length is the meter (m). It is defined as the distance traveled by light in a vacuum during a specific time interval.
4. Why do we use the metric system?
The metric system, also known as the International System of Units (SI), is used by scientists because it provides a standard system of measurement that is consistent and easy to convert between units. It is also based on multiples of 10, making it more convenient for calculations.
5. How do we convert between different units of measurement?
To convert between different units, you can use conversion factors or conversion equations. Conversion factors are ratios that relate two different units of measurement, while conversion equations use mathematical formulas to convert between units. It is important to pay attention to the units and make sure they are canceled out correctly when converting.
  • Other Physics Topics
  • Classical Physics
