Which Radians to Use in Calculating Phase Constants?
  • Thread starter Thread starter lostie100
In calculating phase constants for oscillations, the choice of radians depends on the context of the problem. For the equation sin(theta) = 1/2, both pi/6 and 5pi/6 are valid solutions, but their implications differ. At pi/6, the oscillation's displacement is increasing, while at 5pi/6, it is decreasing. The specific scenario of the oscillation can guide the selection of the appropriate phase constant. Ultimately, the details of the problem will determine which value to use.
lostie100
I just have a simple question as to which radians to use in calculating phase constants in oscillations.
For example in sin(theta) = 1/2, do I use the (pi)/6 or 5(pi)/6?
The exact question has a diagram and is difficult to explain, but I just want a general explanation.
Thank you!
It's a little hard to answer this without more information. If you're just trying to solve the equation,
\sin \theta = 1/2
then there are more than one solution.
But you did say the problem deals with oscillations and phase constants. Can you use the information that:
1) at pi/6, the oscillation's displacement is increasing
2) whereas at 5 pi/6, the displacement is decreasing
to somehow decide on one value or the other? The answer would depend on details of the problem you are trying to solve.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
