Can Negative Mass be Plugged into Conservation of Momentum and Energy Equations?
  • Thread starter Thread starter pantheid
Negative mass presents challenges when applied to conservation of momentum and energy equations, particularly in elastic collisions. For a -1kg ball colliding with a 2kg ball, results vary, with the positive ball potentially having speeds of zero or negative two, leading to confusion about which outcome is valid. Mathematical applications to negative mass may yield correct calculations, but their real-world relevance is questionable, as negative mass is not commonly recognized in Newtonian mechanics. Although there are theoretical discussions and proofs regarding negative mass, they often lead to predictions that lack empirical support. Further exploration into alternative physics topics may be more fruitful than pursuing negative mass scenarios.
pantheid
I'm trying to plug in negative mass into conservation of momentum and energy equations. I want to see what would happen if a -1kg ball traveling at 1m/s smacks into a 2kg ball in an elastic collision. If the second ball is 1kg, then it remains stationary while the negative ball continues to travel at 1m/s, like they didn't even interact. If its 2kg, I get 2 answers for the speed of the positive ball, zero and negative two. How do I know which is correct?
If you try to apply Maths to a non real problem then you will not get an answer that has no meaning in the real world. Your Maths will give you a correct Mathematical answer if you make all the steps correctly but, as with Computers, GIGO.
I believe there is a proof that Newtonian mechanics hold for negative masses. It can be found on the wikipedia page for negative mass, so technically its not garbage.
The best way to find out is with an experiment, but that is not an option. I have never heard of negative mass being used in Newtonian Mechanics, and most of the time when negative mass comes up in other areas of physics, it predicts things that have never been observed. That doesn't mean that it doesn't exist, but you might be better off researching different topics.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
