arnab ghosh
- 4
- 0
Why are synchronous motors reactance grounded and not resistance grounded like in alternators?
Grounded as in the neutral is connected to the ground by reactor in case of motor . In case of generator , since neutral is grounded with resistance , it helps to control the current and hence suppress stability issues. But I don't get why in case of motor , neutral is grounded through reactance . Will it not lead to resonance issues and surges?Hesch said:What do you mean by "grounded"? As a safety-purpose?
I don't think that is permitted. I think that the motor (shield) must be shortcircuited to ground.
Where is the safety if the resistor/inductor is blown? Then you could act as reserve-impedance to the blown resistor/inductor.
Concerning breaking connections here in the U.S.A., neutral is virtually never broken. At least residentially, most ground fault detection is done at the receptacle. This is because most often it is the most inexpensive way to go. Not always though. The same is true in the U.S.A. concerning the ground wire. The green or bare wire and what they are connected to all the way back to the service is never meant to carry anything except a fault.Hesch said:I've tried to google "HFI-relay+US". There is not much to be found. "HFI-relay" means: "High sensitive current relay" that is measuring the ground-current (if any), using Kirchhoffs current law: Ia+Ib+Ic+Ineutral = -Iground. If Iground is above ≈20 mA, the relay will break everything (except ground) in your installation.
I think you have other rules/laws in US regarding safety, so I cannot answer your question.
Averagesupernova said:detection is done at the receptacle.
Basicly with motors you would get a ground fault with a resistive load in a wye configuration. When all three phases are closed you would have a short to groundarnab ghosh said:Why are synchronous motors reactance grounded and not resistance grounded like in alternators?
