Why can't i apply the simple average velocity formula?
4 replies · 3K views
rainstom07
I'm doing a homework problem (i already know the answer) and i came across an error in my logic/application of the formula Vavg = (v + v0)/2. Hopefully you can help me understand why it's incorrect to use the formula.
x = 12t2-2t3 describes a particle position. the derivative of x = 24t-6t2.
The homework question asked me find the average velocity between t = 0 and t = 3.
Using the formula Vavg = Δx/Δt yields 18 m/s... the correct answer.
When i use the simpler formula: Vavg = (vf + vi) / 2 = (x'(3.0)+x'(0.0))/2 = 18/2. I get 9 m/s which is incorrect.
Adding the velocity at t=3 with the velocity at t=0 and then dividing by 2 should've produced 18 m/s... My logic is clearly wrong, but how?
x' describes the velocity of the particle at t seconds? right?
thanks.
Hello rainstom, welcome to Physics Forums
Your average formula (t0+t3)/2 is only correct if x is a linear function of t ie a straight line.
The function x = 12t2-2t3 is decidedly non linear
The way to derive an average for a non linear function (works for linear as well but is trivial) is to integrate the function and divide by the interval or number of points or samples.
So average = Area/Interval
Does this help and can you now obtain the correct answer?
Thank you! i knew there was some sort of condition attached to the simpler version of average velocity.
^^ yup
I suppose you meant v_avg = (v_0 + v_3)/2 is only correct if v is a linear function of t.?
X must then be a quadratic function of t, and x = 12t2-2t3 isn't a quadratic.
Hello willem2 does this attachment help?
The average velocity is the number which if you multiplied it by the time would give you the total distance travelled.
