Why Carbon Atoms Don't Form Square or Triangular Rings
Carbon atoms primarily form stable cyclic compounds like cyclohexane and cyclopentane due to their ability to maintain bond angles close to the ideal tetrahedral angle of 109.5°, which allows for effective orbital overlap. In contrast, triangular (cyclopropane) and square (cyclobutane) structures have bond angles of 60° and 90°, respectively, leading to significant strain and instability in these compounds. While some triangular compounds like cyclopropene can be stable under certain conditions, they generally exhibit higher reactivity due to weak C-C bonds. The stability of cyclic compounds is further explained by VSEPR theory and molecular orbital theory, which highlight the importance of hybridization and orbital geometry. Overall, carbon's preference for forming stable rings is dictated by the geometry of its bonding and the resulting molecular strain.
AlchemistK
I have heard of carbon compounds in the form of rings or circles like cyclohexane and cyclopentane and it set me wondering of why carbon atoms do not form square or triangular rings. Could someone explain the reason?
Chemistry news on Phys.org
Google cyclopropane and cyclobutane.
They do form triangular and square compounds, but they are often unstable. It has to do with the geometry of the orbitals/location of their electrons. There are certain "idealized" bonding angles and triangular compounds and square compounds deviate severely from them. As a result, they do some "weird" bonding.
However, this is a broad generalization. Cyclopropene cation is actually quite stable and can be stored at room temperature with no problems, for example.
The above answers are indeed correct.
Cyclo- butane adn propane are very real, and can be formed.
The answers lie in VESPR thory, relating to the stability (or instability) of the relative orbitals, such as the sp^x hybridized orbits necessary for this particular type of bonding.
Molecular Orbital theory can also give more insight into exactly why or why-not the molecule will be electrically stable, or will display resonance characteristics.
Hi
that's right;
" Besides forming chains, carbon atoms also form rings. The simplest of the cyclic alkanes (general formula CnH2n,,) is cyclopropane (C3H6), shown in Fig. 22.5(a). Since the carbon atoms in cyclopropane form an equilateral triangle with 60° bond angles, their Sp3 hybrid orbitals do not overlap head-on as in normal alkanes [Fig. 22.5(b)]. This results in unusually weak, or strained, C-C bonds; thus the cyclopropane molecule is much more reactive than straight-chain propane. The carbon atoms in cyclobutane (C4HS) form a square with 90° bond angles, and cyclobutane is also quite reactive.
The next two members of the series, cyclopentane (C5H10) and cyclohexane (C6Hd, are quite stable, because their rings have bond angles very close to the tetra-hedral angles, which allows the Sp3 hybrid orbitals on adjacent carbon atoms to over-lap head-on and form normal C-C bonds, which are quite strong. To attain the tetrahedral angles, the cyclohexane ling must "pucker" -that is, become nonplanar. Cyclohexane can exist in two forms, the chair and the boat forms, are shown in Fig. 22.6. The two hydrogen atoms above the ring in the boat form are quite close to each other, and the resulting repulsion between these atoms causes the chair form to be preferred. At 25°C more than 99% of cyclohexane exists in the chair form. "
From Zumdahl chemistry textbook
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
