Why Did My Window Shatter During Nearby Construction?
A member reported that a small double-glazed window shattered during nearby construction, specifically while builders used a pneumatic drill. The discussion highlighted that vibrations from such equipment could potentially cause window damage, especially if the glass was already under stress. However, it was noted that the distance from the construction site might make it unlikely for the drill's use to be the sole cause. For a definitive assessment, an in-person inspection by a local expert was recommended. The thread concluded with sympathy for the member's situation.
May Briscoe
Hi, I'm a new member!
I have double glazing and one of the smaller top windows has shattered. Could the use of a pneumatic drill be the cause?
Regards May.
Regards May.
Well, if you put a pneumatic drill right up to the glass and turned it on, yeah, it could be the cause. Absent that, I think you'll have to help us out with what you are talking about. The use of a pneumatic drill five counties over would not likely be the cause. See how it might be helpful if you were less vague?
This sounds a lot like a "I think my neighbor damaged my property" question. Just to preempt such a question, this is not something a Physics Forum will answer.
Likes russ_watters
phinds said:
Well, if you put a pneumatic drill right up to the glass and turned it on, yeah, it could be the cause. Absent that, I think you'll have to help us out with what you are talking about. The use of a pneumatic drill five counties over would not likely be the cause. See how it might be helpful if you were less.
Hi, sorry I didn't explain myself properly...my age...83. The builders were working next door and they were using the pneumatic drill to go through concrete.
He did knock to ask me to cover up the fireplace as he was concerned that soot might damage the carpet etc!
The noise was horrendous. I won't complain, I just wondered why the window shattered
Welcome to the PF. :smile:
Since they did warn you about falling soot in the chimney, it seems plausible that the vibrations were part of the reason that your window cracked. Likely there were other stresses or other factors that contributed, since all the windows in your home did not crack as well.
But as mentioned already, we generally are not able to help with liability questions here at the PF. For a better opinion, you would need to consult an expert in your area who could conduct an in-person inspection. Sorry about your window!
Thread is closed.
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
