Why do I get a different answer with the parallel axis theorem?
The discussion revolves around calculating the rotational inertia of a system of point masses using the parallel axis theorem. The original poster presents a scenario with four point masses located in the xy-plane and seeks to understand discrepancies between their calculated results and a reference answer from a textbook.
  • The original poster attempts to calculate the rotational inertia using both direct calculations and the parallel axis theorem, questioning the validity of their results compared to the textbook answer.
  • Some participants question the application of the parallel axis theorem, particularly regarding the shift in both x and y dimensions.
  • There is a consideration of whether the center of mass was correctly identified in the calculations.
The discussion is ongoing, with participants exploring different interpretations of the problem and the application of the parallel axis theorem. Some guidance has been offered regarding the correct use of the theorem, but no consensus has been reached regarding the textbook's answer.
Participants note potential discrepancies in the textbook's values, suggesting that errors in mass values could lead to differences in calculated rotational inertia.
catmunch
Why do I get a different answer with the parallel axis theorem? [Solved]
Imagine four points masses m1 = m3 = 3kg and m2 = m4 = 4 kg. They lie in the xy plane with m1 at the origin, m3 at (0, 2), m2 at (2, 2), and m4 and (2, 0). Each unit on the coordinate plane corresponds to a distance of one meter. What is rotational inertia of the system about the z-axis?
Rotational inertia = sum of component inertias
inertia for a point mass = m*r^2
parallel axis theorem: rotational inertia around new axis = old rotational inertia + mass of system * (distance of new axis from old axis)^2
Because m1 is located on the axis of rotation, I ignore it.
inertia of m3 = 3kg * (2m)^2 = 12kg * m^2
distance of m2 from z-axis = sqrt((2m)^2 + (2m)^2) = 2sqrt(2)m
inertia of m2 = 4kg * (2sqrt(2)m)^2 = 32kg * m^2
inertia of m4 = 4kg * (2m)^2 = 16kg * m^2
total = 60kg*m^2
This seemed to be fine, but my book gave me an answer of 56 (with no explanation). Just for kicks, I decided to calculate the rotational inertia of the system around an axis in the center of the four masses (the line defined by x = y = 1).
Then, the masses are all equidistant from the axis with a radius of sqrt(2)m.
So the rotational inertia (through the new axis) would be (3kg + 3kg + 4kg + 4kg) * (sqrt(2)m)^2, or 28kg*m^2.
Then, I used the parallel axis theorem to find the rotational inertia of the system through the z-axis.
new rotational inertia = 28kg*m^2 + (sqrt(2)m)^2*28kg = 56kg
Can anyone see what I'm doing wrong?
Could my problem be that I'm applying the parallel axis theorem to a simultaneous shift in both the x and y dimensions?
I just realized my problem. When using the parallel axis theorem, you need to plug the rotational inertia around the center of mass into the formula. I just took the line that was equidistant from the points.
And then, with the correct center of mass, I again calculate 60kg*m^2. I guess my book must have had a typo. If the authors of my book had mistaken a 3kg mass for a 4kg mass, with a radius of 2m, that would account for the discrepancy.
It must be a typo. It happens quite often with books. Your solution is correct.
ehild
  • · Replies 28 ·
18K
