Why do magnetic fields decay exponentially with depth in a conductor?
Orlando
I am a HS student researching the penetration depths of magnetic fields in conductors. Specifially, I am investigating the exponential decay of eddy currents induced within a conductor in the presence of a rapidly changing magnetic field. I am a bit confused as to why the eddy current density is strongest at the surface of the conductor in a high frequency time-varying magnetic field - can someone explain to me in very simple terms why this occurs?
I can only reason that the magnetic fields generated by the eddy currents at the surface shield the rest of the conductor, however this is very weak reasoning. Does anyone have any ideas?
Your intuition is correct. The induced eddy current is proportional to the magnetic flux enclosed by the path, which in this case is proportional to the field strength. Since a thin layer of eddy current "shields" (partially cancels) the applied field, the next layer down sees a smaller field and carries a smaller current, and so on. The equations governing the exponential decay with depth behave like those governing diffusion (e.g., the conduction of heat into a slab).
Thank you for your response, would you also by any chance know how to calculate the power loss due to eddy currents? I found this from wikipedia:
Under certain assumptions (uniform material, uniform magnetic field, no skin effect, etc.) the power lost due to eddy currents can be calculated from the following equations:
For thin sheets: http://upload.wikimedia.org/math/5/e/e/5ee57c87a0a7375257720d65c5a75198.png
As I am investigating the skin effect, would I be correct to incorporate the exponential decay of the magnetic field as it penetrates the conductor (a function of depth) into this expression if I wanted to calculate the power loss at a particular depth in the material? Or is there a better way to do this?
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
