Why do protons accelerate towards regions of low potential?
Protons accelerate towards regions of low electric potential because it requires work to move a positive charge to a higher potential. The electric field points in the direction opposite to the movement of the proton, indicating that the force acts against the proton's motion. As a result, if only the electric force is acting on the proton, it will naturally accelerate towards lower potential. Understanding the relationship between electric potential and force is crucial in this context. This fundamental principle explains the behavior of protons in electric fields.
FelixISF
I am a bit confused, because I was trying to solve a question involving lines of constant electric potential and protons/electrons which move through this field.
Now, I noticed that I do not know why protons do accelerate towards lower potential?
Could somebody please explain the reasoning behind this from the first step on?
Thanks for your support!
Felix
Which way does the field point?
I am only given a picture of lines of constant electric potential. the lines are all bent around some centre point and at various distanctes from the point.
The highest potentials are near the point. The lowest are far away.
Does that help ?
You need to understand the meaning of potential. It requires work to move a positive charge to a region of higher potential. So which way must the field point and the force act?
The field points in the direction opposite of the movement of the proton and the force acts directly opposite to the movement right?
That means, that if no force other than the electric force is acting on the proton, it will automatically accelerate towards lower potential right?
Exactly!
