Why do the E-field and B-field have different units?
The discussion centers on the differing units of the electric field (E) and magnetic field (B) in electromagnetic theory, specifically in the context of the equation E = cB. It is noted that while E and B have different units in the SI system, they can share the same units in the CGS system, where the Lorentz force equation reflects this equivalence. The confusion arises from the fact that, unlike other physical quantities such as force and pressure, E and B do not scale by a simple dimensionless constant across unit systems. The relationship between E and B is rooted in Maxwell's equations, which govern electromagnetic phenomena. Understanding these differences is crucial for grasping the underlying physics of electromagnetic waves.
tiredryan
Note this is more of a coursework theory question then a specific homework question.
I am learning about E and B fields and electromagnetic waves. A common EM figure I find is the propagation of a photon where the E and B field propagate through space as seen in the following link.
http://www.astronomynotes.com/light/emanim.gif
The confusing thing is that the E field has different units than the B field where E = cB. Is there a physical meaning to this or should I just accept the equation as it is? I am guessing it falls out of Maxwell's equations, but it feels odd that an E and B field have different units when things like the units of force and pressure don't change.
E = cB
F = q(E + v x B)
The Magnetic Force on a moving particle is proportional to its velocity. If you wish to use q \vec v \times \vec B to describe the force, then obviously you can't have the same units for E and B.
There are, however, different systems of measurement where E and B -do- have the same units. One such system is the CGS system. In that system, the Lorentz Force is: q(\vec E+\frac{\vec v}{c} \times \vec B) and there E and B do have the same units.
Thanks for your response. Can you explain how the CGS works to an introductory physics student? How does E remain the same, but B changes by a factor of distance/time in a different unit system? When I think of feet and meters, they scale by a dimensionless constant. Similarly pressure can be expressed in Pa, torr, and bar and the only difference is a dimensionless constant scaling factor. Is there some unit system where length and pressure has the same units? How does CGS work differently?
