Why does the entropy of the Universe always increase?
Entropy (S) of the universe must always increase due to the second law of thermodynamics, which states that real processes tend to move towards states of higher disorder. In reversible processes, entropy remains constant, but in spontaneous processes, the overall entropy of an isolated system increases. When heat transfers from a hot object to a cold one, the entropy lost by the hot object is smaller than the entropy gained by the cold object, leading to a net increase in entropy. The universe began in a low-entropy state, and as systems evolve, they are more likely to occupy high-entropy states. Understanding these principles clarifies why entropy is fundamentally linked to the direction of natural processes.
Est120
i don't really understand why S of the universe must be always positive,i know that only reversible process have constant entropy but why real proceses always increase S in the universe?
sorry for bad english I am not from USA or UK
Science news on Phys.org
Likes davenn
Can you think of any spontaneous process on any scale whatsoever for which the entropy of an isolated system does not increase? Just identify one such process.
Likes davenn
There are several different ways to look at it. One definition of "entropy" is the thermodynamic definition:
##\Delta S = \dfrac{\Delta Q_{rev}}{T}##
where ##\Delta S## is the change in entropy and ##\Delta Q_{rev}## is the heat added to the system (or removed, if ##\Delta Q## is negative) and where ##T## is the temperature (in Kelvin). (The subscript "rev" means "reversible"; basically, it's the heat that would be added if you had made the change slowly and reversibly.)
So if you transfer heat from a hot object (one with a large value of ##T##) to a cold object (one with a small value of T), then the entropy change of the hot object is negative, because it's losing heat, so ##\Delta Q## is negative. The entropy change of the cold object is positive (because ##\Delta Q## is positive, since it's gaining heat). But since entropy is inversely proportional to temperature, the amount of entropy lost to the hot system is smaller than the amount of energy gained by the cold system.
So saying that entropy always increases boils down to saying that if you put a hot object into contact with a cold object, the hot object gets cooler and the cold object gets warmer. If you want to know why THAT always happens, you've got to go a little deeper.
A better question would be "Why did the universe begin in a low-entropy state?". The constant increase in entropy is just because a system in a random state is much more likely to be in a high-entropy state that in a low-entropy one.
