B Why exp(ikx-iwt) and not exp(ikx+iwt)?
  • B
  • Thread starter Thread starter Isaac0427
Isaac0427
Insights Author
The time independent free particle is described by the equation ##e^{i(kx-\omega t)}##. Why do we use this equation instead of ##e^{i(kx+\omega t)}##. I know the answer is "because that's how nature works," but I want to know why we think nature works that way. Where did we get these equations from? Why was ##e^{i(kx-\omega t)}## postulated and not ##e^{i(kx+\omega t)}##?
Thanks!
The time exponent part is just the solution to a time independent Hamiltonian inserted into Schrodinger's equation, there really isn't much more to it... now if you want to ask how come Schrodinger's equation describes nature then you're out out of luck pal.
Both forms are solutions to Schrödinger's equation. See for yourself by substituting each one into the SE.
But with the exp(ikx+iwt), the energy would be negative. This is because the energy operator is iħ∂t instead of -iħ∂t as it is in the momentum operator (of course in the momentum operator the derivative is with respect to position). I've always thought the energy operator was defined that way because of the sign on iwt. So I'm getting that this is just a convention so that the function evolves with time in a certain way.
You're right, the solution with ##+i \omega t = +iEt/\hbar## isn't valid. Somehow I was thinking of these versions: ##e^{-i(\omega t - kx)}## and ##e^{-i(\omega t + kx)}## which puts the ± on the kx.
As to why it has to be ##-i \omega t = -iEt/\hbar##, have you seen how to solve the free-particle SE by using separation of variables, i.e. ##\Psi(x,t) = \psi(x)f(t)##?
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
I asked a question related to a table levitating but I am going to try to be specific about my question after one of the forum mentors stated I should make my question more specific (although I'm still not sure why one couldn't have asked if a table levitating is possible according to physics). Specifically, I am interested in knowing how much justification we have for an extreme low probability thermal fluctuation that results in a "miraculous" event compared to, say, a dice roll. Does a...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
