Why, IF electrons really orbited atoms, would they lose energy?
Electrons orbiting atoms would lose energy due to their changing electric fields, which result from their motion. As an electron moves, it creates a varying electric field that leads to the emission of light. This process is linked to the principles of electromagnetism, where a changing magnetic field induces a changing electric field. The discussion emphasizes that a moving charge alters the electric field at fixed points in space, confirming that the electron's position affects the field's strength and direction. Ultimately, this dynamic interaction explains why orbiting electrons would lose energy over time.
bananabandana
I realize they're meant to emit light. But why? I understand vaguely that the E field might be changing with time, since you have a changing magnetic flux... but where does the changing E field come from? Unless I guess it's just a self supporting process (changing B field *causes* changing E here...) - is that just what a light ray is??
Many Thanks!
Draw up a picture of a simple atom, like a hydrogen atom. Ignore the contribution from the atom core to the electric field.
Pick a random point and write down the electric field in that point, draw it again after half a period (For the orbiting electron).
Will the electric field be different in the two pictures.
Oh right, for sure. The electron is at a different distance from the point! Sorry!
A moving charge always produces a changing E field, that should be obvious. Take any fixed point P in space. At some time, the charge Q is at distance A from P. At some other time, Q is at distance B from P. Because A and B are different, the E field at P must also be different.
