Is 'g' Negative? Understanding the Confusion of Definitions
  • Thread starter SecretSnow
  • Tags
    Negative
In summary: The force of gravity on an object of mass m is given by ##\vec{F}_g=m\vec{g}##, where ##\vec{g}## is the acceleration due to gravity. The magnitude of this vector is given by ##|\vec{g}|=9.8~m/s^2##, and its direction is downward (-z) for any object near the Earth's surface. (This is what we mean when we say "the acceleration due to gravity is 9.8~m/s^2.")On the other hand, the potential due to a mass M is given by ##\phi=-\frac{GM}{r}##. This is just a scalar - it has no
SecretSnow
66
Hi guys, I understand that g is by definition positive, as in the Gravitational field strength. However, my school's notes has defined g as
-(GM)/r^2. I don't understand what's that negative sign for, and in what scenario is the negative sign used? By the way, it also defined g as -(d phi/dr) where phi is the gravitational potential and d is the differentiation sign...in this case, it says F=-Gmm/r^2.
Thanks a lot!
g is the acceleration due gravity. It is attractive that is why taken as negative. It is just a reference that attractive forces are taken negative while repulsive forces are taken positive.
Thanks a lot!
The sign of the acceleration is to do with the direction. If "up" is taken to be positive, then the acceleration of gravity will be negative. Since F=ma, this means that the force is also negative.
That is all there is to it.
When you are given potential ## \Phi ##, then the equation for the strength of the field in direction ## n ## will have the minus sign by definition: ## g_n = - \frac {\partial \Phi} {\partial n} ##.
In the case of (Newtonian) gravity, the potential for the field of a spherically symmetric mass is given by ## \Phi = - \frac {GM} {r} ##, where ## r ## is the distance from the center of the mass, and, when the direction is ## r ##, the strength is given by ## g_r = - \frac {\partial \Phi} {\partial r} = - \frac {\partial } {\partial r} \left( - \frac {GM} {r} \right) = - \frac {GM} {r^2} ##. Because ## r ## is the direction from the center, the minus sign in the resultant equation for the strength indicates that it is against the direction, that is, the force is toward the center. The latter is what we physically know about gravity, and that is why we have the minus sign in the original equation ## \Phi = - \frac {GM} {r} ##: we want that when we apply mathematics to find the force, we obtain physically sensible results.
I have never seen g = -GM/r^2 in any textbook ! If it is defined like this then the force of gravity on an object should always be written F=-mg...have you ever seen this, It is unusual.
What exactly do you mean by 'school notes'...is it in a textbook?
It looks (to me !) like some confusion between the force of gravity and gravitational potential
That was exactly what I was about to write.
Some texts define down as positive for some problems, and then g is positive. Most introductory physics texts use height above the surface as the dependent variable, making g negative in this context. (Note that it's intro physics texts where this issue of g being a signed scalar arises; you'd be using vectors otherwise.)
Which of upwards or downwards is arbitrarily be positive dictates the sign of g. There's nothing physical going on. It's just a sign convention.
For a mass 'm' the force of gravity on the mass is 'F' so F = mg.
F and g are bound to be in the same direction (only attraction is possible in gravitation!) so we should write
F = mg ? Or...
-F = -mg ? ...purists may see a subtle physics relevance.
Never seen this referred to in standard textbooks until the topic of potential is raised.
You are putting way too much emphasis on this, technician. It's just a sign convention on whether upward vertical displacement is positive or negative: Height versus depth. If height is the dependent variable, then acceleration due to gravity is -9.81 m/s2. Does it make one bit of difference if I use g = 9.81 m/s2, in which case acceleration due to gravity is a=-g, versus using g = -9.81 m/s2[/sup, in which case acceleration due to gravity is a=g?
To me its better to assign coordinates later rather than sooner (in which case g is unsigned 9.81 m/s2 rather than +9.81 m/s2), but that's personal preference. There's nothing wrong with the other approach.
Thanks a lot!
g is a vector, directed towards the Centre of Mass.
r is the displacement out from from that C of M.
If we take the r direction as positive, then the g direction must be negative.
The negative sign is probably just to emphasise that g and r have opposite directions.
F = mg ? Or...
Yes you have - all the time.
It's in all that work on vectors.
Both the expressions above should read ##\vec{F}=m\vec{a}##
If we choose our coordinate system so that the ground is the x-y plane, and the +z axis points upwards, then you get ##\vec{a}=-g\hat{k}## for a mass m in free fall. That is, an acceleration of magnitude ##g## in the ##-\hat{k}## direction.
Similarly, the force on mass ##m_1## due to mass ##m_2##, is properly given as: $$\vec{F}=-\frac{Gm_1m_2}{r_{21}^3}\vec{r}\!_{21}=\frac{Gm_1m_2}{r_{12}^3}\vec{r} \! _{12}$$ ... where ##\vec{r}\!_{ab}## is a vector pointing from the position of ##m_a## to the position of ##m_b## ... notice how the minus sign depends which way the radial vector points?
These expressions are found in good textbooks ... poor textbooks may just expect you to join the dots between the work you do on vectors earlier in your education and the gravity stuff they do.
PeterO said:
G is a vector, directed towards the Centre of Mass.
'G' a vector!. Sure?
Was trying to type g, but instinctively pressed shift at the start of the sentence.
g certainly doesn't point the same direction in Rio as it does in New York. g is a scalar. Some intro level texts might use g as a signed scalar with a negative value. I'm not thrilled with that, but it's not invalid. Calling g a vector is invalid.
D H said:
hen we have the weight Force F = mg, The Force, like all Forces, is a vector, but mass is a scalar. Where else does F get its vector reference, but from g?
The vector form of Newton's law of gravitation is
[tex]\begin{aligned}
\vec F &= -\,\frac {GMm}{||\vec r||^3}\vec r \\
&= -\,\frac {GMm}{||\vec r||^2}\frac{\vec r}{||\vec r||} \\
&= -\,\frac {GMm}{||\vec r||^2}\hat r
\end{aligned}[/tex]
The linearization of this for points near the surface of the Earth is
[tex]\vec F = -mg \frac{\vec r}{||\vec r||} = -mg\hat r[/tex]
So where does F get its vector reference? From the radial vector. Not from g. g is a scalar, and it's best expressed as an unsigned scalar.
Never seen g or G written as Vectors in any textbooks. What I know is both g and G are constants. By definition both g and G are different. The relation OP wrote between G and g is seldom used as g is well defined constant as the acceleration due to Earth's gravity.
So g is not a vector, yet acceleration is?
I didn't want to post here because many people have already answered the main question with very simple answers. Regardless, ##\mathbf{g}## is certainly a vector, what else did you think it was? Acceleration is a vector by definition. The Newtonian field is given by ##\mathbf{g} = -\frac{GM}{r^{2}}\hat{r}##. When you are standing on the surface of the earth, the gravitational field is approximately uniform and takes the form ##\mathbf{g} = -9.81\frac{m}{s^{2}}\hat{z}## where ##\hat{z}## is the upwards vertical direction. More generally, the gravitational field can be defined as the negative gradient of the gravitational potential ##\mathbf{g} = -\nabla \Phi## as voko pointed out; this is obviously a vector field.
Yes because it always say that acceleration due to gravity is downwards. If g was vector they need not write that acceleration is downwards every now and then!
It is very standard notation to use ##\mathbf{g}## to represent the gravitational field. Just because you yourself have never seen it doesn't mean it isn't standard.
You are merging two different things here. g and Gravitational field are two very different things. Gravitational field is definitely a Vector. The values of acceleration and Field are same in a Gravition but they are very different quantities. Remember when we solve classical mechanics question, we never take g as a vector there.
JIC: I edited my post #10 above to be clearer ... while I was doing that there were a lot of extra answers.
I think we all agree that the sign in the expression for the gravitational force is for direction and depends on the sign-convention for directions that are chosen and must reflect that gravity is attractive.
But if it is a standard notation then it should be written down someplace - perhaps in some standard reference... and you will be able to provide a link to this?
I think this is a side issue to OPs question.
OPs confusion likely arises because of the common practice of working in 1D and using a sign convention to specify direction while all other variables are magnitudes.
That 9.81 m/s2 (more precisely, 9.80665 m/s2) has a name. It's g (more precisely, it's g0, but hardly anyone uses that subscript 0.). It's an SI defined constant. I personally prefer [itex]\vec a_g[/itex] as opposed to [itex]\vec g[/itex] to denote acceleration due to gravity to avoid confusion with that scalar.
Sure but I was talking about technician's opposition to the statement that g = GM/r^2 is never used. The MIT OCW link above for example serves as a counter example.
I was just going though a book by Bernstien, Fishbane. I think i just found the answer to the discussion.
They distinguish the Local gravity and Gravition. I would agree with with technician here that g= GM/r^2 is never used. The g technician is talking about is the local gravity constant which definitely is sclalar constant(a well defined one).
And the g you are talking about is gravitation field, which is vector of course.
The conventiin you are using to define g as gravitation field might be common in some texts but is not universally common. I haven't seen any of books.
Big answers. By the way if you take a particular vector direction as positive then the opposite direction will be negetive. Here we can take downward direction accelaration due to gravity "g" as positive. But many a times it is just taken as negetive in order to coincide with the cartesian co ordinate system in which the vertically down direction is -y a negetive.
In the end this all boils down to what is denoted by 'g'. There can be subtle differences, which may or may not be indicated by the type face or some other symbolism. It is not uncommon in physics and mathematics to denote closely related concepts by identical letters and varied shapes, accents, subscripts and superscripts. Which does get confusing at times, and texts are not always consistent.
If 'g' is the magnitude of the Earth's standard sea-level acceleration of gravity, then it is a positive scalar by definition. If it is anything else, and it can be, its definition must be carefully consulted.
Related to Is 'g' Negative? Understanding the Confusion of Definitions
1. Why is g Negative?
Gravity (represented by the letter "g") is a fundamental force of nature that attracts objects with mass towards each other. In our everyday experience, we usually observe gravity as a positive force, keeping our feet on the ground and objects from floating away. However, in scientific equations and calculations, gravity is often represented as a negative value. This is because gravity is a vector quantity, meaning it has both magnitude and direction. In equations, the direction of gravity is often represented as downwards, which is assigned a negative value.
2. How is g Negative Measured?
The strength of gravity, or the acceleration due to gravity, is measured using a unit called meters per second squared (m/s²). This unit represents the amount of change in velocity per unit of time. For example, on Earth's surface, the acceleration due to gravity is approximately 9.8 m/s². This value is a negative number because it is directed towards the center of the Earth.
3. Does g Negative Affect Objects Equally?
No, the strength of gravity (represented by g) varies depending on the mass and distance between objects. The more massive an object is, the greater the gravitational force it exerts. Additionally, the farther apart two objects are, the weaker the gravitational force between them. This is why we experience a stronger gravitational pull towards the Earth's surface, where the majority of its mass is concentrated.
4. Are There Any Other Factors That Affect g Negative?
Yes, there are several other factors that can affect the strength of gravity. One of these factors is altitude, as the farther away an object is from the Earth's surface, the weaker the gravitational force becomes. Another factor is the shape of the Earth, as it is not a perfect sphere and has variations in its gravitational pull due to its uneven mass distribution.
5. How Does g Negative Impact Everyday Life?
The negative value of g has a significant impact on many aspects of our everyday lives, from keeping objects on the ground to determining the trajectory of a rocket launch. Without the negative value of g, we would not be able to accurately predict the motion and behavior of objects in our physical world. Understanding and utilizing the concept of g is crucial in many scientific fields, such as engineering, physics, and astronomy.
