Why is HF Not a Lewis Base and MgBr2 a Lewis Acid?
  • Thread starter Thread starter asdf1
HF is not considered a Lewis base primarily due to the strong electronegativity of fluorine, which holds onto its electrons tightly, preventing effective donation. Although F- has lone pairs, the hydrogen in HF is weakly bonded and can participate in proton donation, allowing HF to act as a Lewis acid in certain contexts. MgBr2 is classified as a Lewis acid because it can accept electron pairs, while lacking the ability to donate electrons, thus not qualifying as a Lewis base. The behavior of these compounds can vary depending on the reaction environment, such as in aqueous solutions where HF behaves as a stronger acid. Overall, the classification of HF and MgBr2 hinges on their interactions and the specific chemical context.
asdf1
why's HF not a lewis base? doesn't F- have lone pairs which could be used to donate electrons?
why's MgBr2 a Lewis acid and not a lewis base?
well to start with, since F has three lone pairs, it would seem to be a good explanation, except that it is so electronegative that most of the time, electron of hydrogen are with F instead, giving it a dipole moment. A Lewis acid is when it can accept electrons or donate protons, in this case it could do that because hydrogen is just hanging there barely (F is so negative that the hydrogen bond can easily break).
Depends on what context you're referring to. HF can act as a lewis base, when it participates in intermolecular hydrogen bonding (and a lewis acid in this case). The LUMO on the hydrogen will interact with the HOMO on the Flourine.
In aqueous solutions, and in the case of its reaction with water, it's an acid, that is the stronger acid.
In either case you've got to consider what the compound is reacting with.
thank you very much! ^^
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
