Why is normal force in a satellite zero?
In a satellite, the normal force is zero because both the satellite and any object inside it, such as an astronaut, are in free fall, creating a weightless environment. This condition is similar to an elevator in free fall, where the normal force also becomes zero. The astronaut does not need a normal force to prevent falling through the floor since both are falling at the same rate. The concept can be understood through Newtonian gravity, where the normal force is only necessary to counteract gravity when an object is not in free fall. Thus, in orbit, there is no requirement for a normal force, as the gravitational pull and centrifugal force are balanced.
Yatin
Gravity does act on a satellite so why is normal force 0 for an object placed inside it?
Astronomy news on Phys.org
The force is not zero. Both the object and the satellite are in free fall, so the object appears weightless in the frame of reference of the satellite.
Likes Yatin
I think by "the normal force" it is meant the force of the floor of the spaceship on the astronaut, which would indeed be zero. Interestingly, there are two very different ways of explaining that, based on which theory of gravity is used, but it's clear you mean Newtonian gravity, rather than general relativity. In Newtonian gravity, we can say that the normal force is zero because the astronaut and the spaceship are both in free-fall, just like how the normal force goes to zero in an elevator when the cable breaks. After all, the normal force acts to produce just the force needed to keep the astronaut from falling through the floor, but no force is needed when the floor is falling already, as in an orbit. Another way to see that is to imagine removing the spaceship altogether, and the astronaut will still be in orbit and still follow the same motion. So clearly there is no place or need for any normal force.
its in free fall as already noted, centrifugal force is balanced by gravity
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
