Confusing Physics Concepts Explained: Solving for Net Force and Fx
  • Thread starter Thread starter Aladdinnas
    Confusing Physics
The discussion revolves around the confusion experienced by a student regarding physics concepts, particularly in calculating net force and forces acting on a space shuttle. The student attempts to solve a problem involving the shuttle's acceleration and mass, applying the formulas for net force and force (F=ma). They express uncertainty about how to find the horizontal component of force (Fx) due to the absence of a right angle in the scenario. The student realizes that their question is more suited for a homework help forum rather than a general discussion. This highlights the common challenges students face in understanding complex physics problems.
Aladdinnas
Why is physics so confusing?
Hey, it's my first time here...cz i need serious help.
My teacher gave us a review sheet for a big test, and he expects me to do it, even knowing that i jus moved into this class...
I've got most of the notes...but i still find things confusing...
For Question#1
Fnet = Fg-Fn
=(-5.586x10(p6))+(1.5x10(p7))
=9.414x10(p6)
F=ma
=29.4x5.7x10(p5)
=1.6758x10(p7)
I understand the concept so far...but since the angle will NOT create a right angle, i need to find another method of getting Fx.
here is the question
1. During a space shuttle flight, an acceleration upward of 29.4m/s2[Y15X] is measured. Assuming that the shuttle has a mass of 570000kg, calculate the force that the small maneuvering thrusters would have to fire at to accomplish this. The main engines provide a force of 15000000N [Y] upward.
opps...i jus realized...this dosent belong in this forum...it's needs to be sent to the homework help forum
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
