photobillyli
- 5
- 0
Why is the kinetic friction always smaller than the limiting static friction?
Thank you very much!
Thanks!kreil said:It is based on the concept that it takes more force to accelerate a mass from rest than to keep it moving.
I have done an experiment to study the relationship between the static friction and kinetic friction of a wooden block.radou said:This link should help: http://hyperphysics.phy-astr.gsu.edu/hbase/frict2.html" .
Interaction between the surfaces is more established when the surfaces are at rest.Why is the coefficient of kinetic friction smaller than the coefficient of static friction?
Not quite. In the hyperphysics link provided by radou, it inidicates the kinetic friction is "the frictional resistance is almost constant over a wide range of low speeds", which implies that at higher speeds, the relationship is not necessarily constant.1. In fact, the frictional force had no any relationship to the velocity of the body. Many people believe that the friction to be overcome to get something started(static friction) exceeds the force required to keep it moving(kinetic friction), but with dry metals it is very hard to show any difference.
If an applied force exceeds the kinetic friction force, then a sliding body will accelerate. Once a body starts to move, the applied force may be decreased to a level equal to the kinetic friction force, and the body would move at constant speed.On the other hand, when the body started moving, it tended to remain moving at constant speed. The applied force did not needed to overcome the body’s inertia but just needed to overcome the friction.
The surface properties do not change (more or less), but the interaction changes. On the other hand, the 'effective roughness' of either or both surfaces may change with the application of shear forces due to motion.Moreover, how the irregular surfaces, impurities, or other factors make the difference between static friction and kinetic friction of the wooden block?
#2 is not valid. You are comparing the forces, not the motion. An object has inertia whether it is moving or at rest. It takes the same amount of force to cause the same change in velocity regardless of what the initial velocity is. #1 is is in the right direction.photobillyli said:I have done an experiment to study the relationship between the static friction and kinetic friction of a wooden block.
I have found that the static one was larger than the kinetic one.
My textbook also tells me that result.
However, that web tells me that there should be no any difference between static and kinetic friction.
Then, what should I answer to the question:
Should I write
The difference between static friction and kinetic friction of the wooden block was because of irregular surfaces, impurities, or other factors. (It is taken from that web)
or
2. It can be explained by the inertia.
When the body was at rest, it tended to remain at rest. The applied force had to overcome both the static friction and the inertia.
Therefore, the force needed to keep a body moving was smaller than to start a body to move. (It is the explanation I thought)
For a rough surface, the molecular attraction is probably a minor contributor to the total friction. It is more likely that the sideways force of friction is a reaction to trying to push the nestled surface peaks over one another. If the molecular forces become the dominant effect, then I suspect friction would behave rather differently from what we usually observe.photobillyli said:Thanks for OlderDan's detailed explanation.
Let me to answer my question.
There are always irregularities between the surfaces. The peaks of one surface will fit into the valleys of the other surface. A larger applied force is needed to starts the body's motion.
On the other hand, when the body is moving on a surface, it will separate from the surface. The body is just jumping up and falling down although we can not see the jumping. There will be a very small(relatively) friction during the period that the body is separating from the surface. Although this period of time is short, it happens many times during the motion.
As a result, the kinetic friction will be smaller than the static friction.
I have got some questions, you said"Greater separation means that only the peaks of the surfaces are coming into contact at points closer to the tips of the peaks. There will be a reduced attraction between the molecules of the two objects."However, the law of friction states that friction has no relationship to the contact surface area. Then, how "only the peaks of the surfaces are coming into contact at points closer to the tips of the peaks" can reduce the friction??
Besides, how this effect disappear on dry metals?
Thank you!
The simple answer to this question is: if the initial kinetic friction force (ie. applied force - maximum static friction is arbitrarily small) was higher than static friction, the object would not begin to move - so we would call it static friction. If the object begins to move, then necessarily the force of kinetic friction has to be less than the maximum static friction force.photobillyli said:Why is the kinetic friction always smaller than the limiting static friction?
I get your point about why kinetic friction cannot be greater than static friction, but I do not agree with your conclusion. If the coefficient of kinetic friction and the coefficient of static friction were identical, then if I placed an object on an adjustable incline I could find an angle where the object could be placed at rest and stay there (static) or give the object an initial speed down the plane and have it move with constant speed (kinetic). An infinitesimal increase in the pitch of the plane would result in an infinitesimal net acceleration. An infinitesimal decrease in the pitch would result in the object remaining stationary if placed, or coming to a stop if given an initial velocity.Andrew Mason said:The simple answer to this question is: if the initial kinetic friction force (ie. applied force - maximum static friction is arbitrarily small) was higher than static friction, the object would not begin to move - so we would call it static friction. If the object begins to move, then necessarily the force of kinetic friction has to be less than the maximum static friction force.
AM
When carefully standardized surfaces are used to measure the friction coefficients, the difference between static and kinetic coefficients tends to disappear, indicating that the difference may have to do with irregular surfaces, impurities, or other factors which can be frustratingly non-reproducible.
There may be cases where they are about the same, but if they were exactly the same there would be no minimum speed. The object would begin to move at an arbitrarily small speed as soon as the maximum static friction force was reached. But if that was the case, we could not call it the maximum static friction - because it is moving (albeit at an extremely slow speed)!OlderDan said:I get your point about why kinetic friction cannot be greater than static friction, but I do not agree with your conclusion. If the coefficient of kinetic friction and the coefficient of static friction were identical, then if I placed an object on an adjustable incline I could find an angle where the object could be placed at rest and stay there (static) or give the object an initial speed down the plane and have it move with constant speed (kinetic). An infinitesimal increase in the pitch of the plane would result in an infinitesimal net acceleration. An infinitesimal decrease in the pitch would result in the object remaining stationary if placed, or coming to a stop if given an initial velocity.
What we emprically observe is that if an object is at rest and we gradually increase the pitch, it remains at rest until a critical angle is reached and the object suddenly has a finite acceleration. There is no gradual change between zero acceleration and the mimimum acceleration. So we must conclude that it is possible (and common) for the kinetic friction to be less than the maximum static friction, but that does not require the kinetic friction to be less than the static friction. The world would be just fine if they were the same. According to that article at hyperphysics, it has been shown that there are cases where the two are the same.
It (the object on a plane) would not begin to move when the gravity component just reached the maximum static frictional force. It would be in equlibrium. It would only begin to move if given a nudge by an external agent, and then it would move with constant velocity, or it would begin to move with acceleration if the gravity component exceeded the maximum static friction. If the kinetic friction were even the slightest bit less then the maximum static friction, the nudge while at maximum static equilibrium would get the object moving and then it would necessarily be accelerating. There is no fundamental reason why this has to happen.Andrew Mason said:There may be cases where they are about the same, but if they were exactly the same there would be no minimum speed. The object would begin to move at an arbitrarily small speed as soon as the maximum static friction force was reached. But if that was the case, we could not call it the maximum static friction - because it is moving (albeit at an extremely slow speed)!
This is a separate issue. Kinetic friction could certainly be speed dependent.Andrew Mason said:Now, once it is moving it is certainly possible that the coefficient of kinetic friction could increase with speed so that the kinetic friction at a particular speed is greater than the maximum static friction force. But not at an arbitrarily small speed.
AM
