Why is the weight going upward? Statics
  • Thread starter Thread starter asz304
    Statics Weight
In the discussion about the problem linked, participants clarify that the weight W is represented as acting upwards in the free body diagram (FBD) of joint A due to the upward force exerted by the chain AE, known as Fae. This upward representation is necessary to ensure a positive calculation for the forces involved, as a downward weight would result in negative forces, indicating opposite directions. The participants agree that W represents the tension in the string, which is crucial for understanding the system's dynamics. Additionally, there is a reminder to adhere to international standards for unit notation, emphasizing proper spacing between numeric values and unit symbols. Understanding these concepts is essential for accurately analyzing static systems in engineering.
asz304
http://www.engr.mun.ca/~neil/1010/prob11/set2.pdf"
In the first problem in the link above, why is the weight pointing upwards instead of downwards? I thought there will be a different force prolly called Fae pointing upwards with the weight pointing downwards.
Thanks
In the first part I think they just used W to represent the force acting in the vertical chain connected to A.
But in the calculations, W = mg, where m = 200kg. I still don't get it...
Yeah I see it now. Not too sure why exactly they did that other than to get a positive answer. If you had W acting downwards, then you'd get the two forces to be negative meaning that the forces act in the opposite direction.
asz304: W points upward in the FBD of joint A because chain AE applies an upward force on point A, called Fae, where Fae = W. If you wish to write vector Fae, that is fine. And the magnitude of vector Fae is W; i.e., Fae = W.
By the way, always leave a space between a numeric value and its following unit symbol. E.g., 200 kg, not 200kg. See the international standard for writing units[/color] (ISO 31-0[/color]).
W must mean Tension in the string. It can't be anything else.
