Why photons can't afford more than light speed ?
Photons cannot exceed the speed of light due to the nature of space-time, not limitations imposed by E=mc^2. While all particles adhere to this equation, it primarily applies to massive bodies, which cannot reach light speed. For massless particles like photons, momentum is described by p = E/c, allowing them to travel at speed c. The relationship between wavelength and frequency also confirms that light's velocity is constant, as derived from Maxwell's equations. This fundamental property of light, consistently observed in experiments, underpins the theory of relativity.
oneat
Why photons can't afford more than light speed?
They are not limited by E=mc^2.
Science news on Phys.org
It is the nature of space-time. Read up about Special Relativity, then come back to the question.
No, all particles obey this equation. Even photons. Obviously you cannot use the usual gamme factor.
But that equation is not even what shows that normal matter can't go at light speed.
It is shown with:
p = \gamma m v
But, this is the equation for bodies with mass only and it shows they cannot reach c.
For massless particles (photons) the above equation does not apply, you must use this instead:
p = \frac{E}{c}
which doesn't have the same problem. Furthermore, we know that for waves the wavelength * frequency = velocity of the wave, but for light the wavelength and frequency are inversely related by the constant c, so when you find wavelength*frequency you get that they equal "c", which should be the volocity, so v=c.
I'm just sort of beating around the bush though, there are much better explanations. I know there is a way to derive it from maxwell's equations.
Sorry I can't give a better explanation but that is why I didn't respond to this thread right away, I waited a day.
The fact that light always has speed c, relative to any observer, is a result of experimental evidence. It is not proven from other properties, other properties are derived from that observation.
you can show that light travels at c with maxwells equations
c= 1/(sqrt(eq))
where e= permittivity constant
q= magnetic constant
and when maxwell came across this result , he realized that this was always constant no matter how fast you were going , and this was always in the back of his mind ,
And Einstein used this fact to start creating relativity ,
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
