- #71
PeterDonis
Mentor
- 45,650
- 22,665
Mister T said:let's look at Mermin's way of writing ##c## as ##1## phoot per nanosecond, where the phoot is defined as ##0.299\ 792\ 458## meters
And how is a meter defined? If it is defined as the length of a particular stick somewhere, then you are correct that the phoot and the nanosecond are different units (since the nanosecond is defined in terms of the second, which is defined in terms of a particular atomic transition frequency).
But if the meter is defined in the SI manner, as the distance light travels in a certain fraction of a second, then the phoot and the nanosecond are the same unit, just with two different names for historical reasons. With the phoot defined in this way (using the SI definition of the meter), the speed of light has to be ##1##, a dimensionless number, because the definitions of the meter and the definition of the second are not independent, therefore the definitions of the phoot and the second aren't either.
The same can be said about SI units; SI units are defined (currently) in such a way that the speed of light has a constant value of 299,792,458. We usually quote this as having units of "meters per second", but this does not express our best value for the speed of light in terms of a relationship between two independently defined physical standards, which is what "different units" would mean. It just expresses the fact that, again for historical reasons, our "standard" units make ##c## be a really wacky dimensionless number, 299,792,458, instead of the obvious dimensionless number 1.
