Wierd Circuit Need Help Figuring it Out
  • Thread starter Thread starter Mopar426Hemi
    Circuit
To determine the total resistance of the circuit, simplify it step by step by identifying resistors in series and parallel. The circuit features a 97.3-ohm resistor at the top, with various resistors including 71.7, 69.8, 71.8, 59.9, 72.6, and 72.2 ohms arranged in different configurations. Begin by combining the three resistors on the left side in series, and then analyze the right side, which contains four resistors in series. After calculating the equivalent resistances, redraw the circuit and continue the analysis until the total resistance is found. This systematic approach will help clarify the overall resistance value.
Mopar426Hemi
I am trying to figure out mathmatically how to come up with the total resistance of this circuit. I have a mock up of it and came up with 232.2+or-. I cannot seem to figure it ouy on my own yet and don't truly have the time to do it. There is a 97.3 resistor on the top and the right side has a 71.7 ohm resistor. Going down the center line is a 69.8 and a 71.8 ohm before a split then another 71.7 Ohm resistor. On the left there are 59.9, 72.6 and a 72.2.
97.3
__________________
69.8 71.7
71.8 |
____________| |
59.9 | |
72.6 71.7 |
72.2 | |
| |__________________|
|___________|
232.2+-?
Simplify the circuit step by step. Find any cases where resistors are purely in series or parallel and replace them with their equivalent resistance. Redraw the circuit and repeat the analysis. Keep doing that until you're done.
For example: In the left loop, there are 3 resistors in series; in the right loop, 4 are in series. Start there.
