Wikipedia article: No time in General Relativity
Nick666
"In quantum gravity, the problem of time is a conceptual conflict between general relativity and quantum mechanics. Roughly speaking, the problem of time is that there is none in general relativity. This is because in general relativity, the Hamiltonian is a constraint that must vanish. However, in theories of quantum mechanics, the Hamiltonian generates the time evolution of quantum states. Therefore we arrive at the conclusion that "nothing moves" ("there is no time") in general relativity. Since "there is no time", the usual interpretation of quantum mechanics measurements at given moments of time breaks down. This problem of time is the broad banner for all interpretational problems of the formalism."
http://en.wikipedia.org/wiki/Problem_of_time
Could you shed some light on this for me ? Is this another way of saying there's no time, only spacetime in GR ?
I think the summary statements in this article are just wrong. Some of the more detailed explanations are ok, but still tend to overstate the case. Solutions considered physically plausible (e.g. FLRW) have a globally well defined time. I have usually seen this discussed more in terms of:
- you want to quantize gravity
- but gravity = curvature = the relation of space and time
- so you suddenly need to have time itself subject to non-determinism
and nobody knows how to do this yet.
The "time" in these spacetimes is a geometric property of the solution (in FRW solutions, for example, it's the "time" defined by the set of "comoving" worldlines and the spacelike hypersurfaces orthogonal to them). But this property in itself does not give you "time evolution" in the sense of QM.
Another way of stating the problem is that, in order to have a Hamiltonian operator that can generate time evolution in the sense of QM, you need a well-defined global notion of energy. But there isn't one in a general spacetime in GR. The best you can do in the general case is to construct an expression that looks like a "Hamiltonian", but vanishes identically (this is the "Hamiltonian constraint"), so it can't act as a generator of anything.
Well, the Wheeler-DeWitt equation does say ##\hat{H} \vert \psi \gt = 0##, which basically amounts to "the wave function of the universe doesn't change". At least, to the extent you can express what it's saying in a short sentence of ordinary language.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
