Fiona Rozario
- 52
- 1
If I had a red laser light, will i be able to see this red beam in space?
I'm not sure you would be able to see the beam coming from the laser light, but you should be able to see it when it hits a solid object.Fiona Rozario said:If I had a red laser light, will i be able to see this red beam in space?
No, I'm saying the reason we see light is because the reflected parts reach our eyes, you would still see the laser, but not the beam like you would on Earth because their is nothing to direct the light to your eyes until it hits something. It may be possible that a camera that uses different methods of capturing images than our eyes do can see the beam, but the naked eye can't see it because the light doesn't reach us. Now the only thing I know that could allow the beam to be seen(however slightly) without an object scattering the light is gravity, but I'm still learning if that's true.Fiona Rozario said:Do you mean to say that light (poly or monochromatic) needs to be scattered by something so that it may be seen?
If the light doesn't reach your eyes, it won't reach the camera.CrackerMcGinger said:It may be possible that a camera that uses different methods of capturing images than our eyes do can see the beam, but the naked eye can't see it because the light doesn't reach us.
It all depends, as does the question in the OP, in the relative orientation of the person and the direction of propagation of the light. Light travels in a straight line unless there is some object to make it change trajectory, through reflection, scattering, bending because of refractive index (e.g., optical fiber), or something similar. If the light is not aimed at your eyes, you won't see it unless part of it gets deviated towards you.CrackerMcGinger said:Now the only thing I know that could allow the beam to be seen(however slightly) without an object scattering the light is gravity, but I'm still learning if that's true.
It needs to reach your eyes to be seen.Fiona Rozario said:Do you mean to say that light (poly or monochromatic) needs to be scattered by something so that it may be seen?
