Will truss linkages diminish vibrations?
  • Thread starter Thread starter Varadha
    Truss Vibrations
Truss linkages can potentially diminish vibrations, but their effectiveness depends on the incorporation of loss elements to absorb impulses before they reach the supported platform. Rigid assemblies transmit impulses faithfully, so strategies such as using elastic mountings, hydraulic bumpers, and varying path lengths are essential for impulse attenuation. Design considerations include using knee joints to prevent axial wave propagation and incorporating materials with different acoustic properties to reflect energy. Additionally, employing a tensegrity structure can enhance vibration isolation. The discussion also seeks recommendations for free online apps to test and simulate truss bridge designs.
Varadha
Is it possible to have a body supported by truss linkages and isolate them from any stresses and impulses?
Say, we are supporting a platform on the top of a set of rigid, pin jointed and cross-linked members. If small impulses act on the bottom on the linkages(upwards), is there any possibility that the impulse does not reach the platform on the top?? Or will there be a significant reduction in its magnitude?
Difficult to see why, unless you factor in real world effects such as slippage and flex between the truss joints.
If the assembly is 'rigid', impulses will be faithfully transmitted. So there must be loss elements in the truss if the impulse is to be attenuated. These can be elastic mountings, hydraulic bumpers or whatever, but their role is to absorb the impulse before it impacts the platform.
Likes 1 person
Analyse the structure as a transmission line network.
Design a structure that sounds dead and does not ring like a bell when hit.
You can reduce the impulse amplitude in a number of ways.
1. Have many different path lengths to spread the pulse in time.
2. Use knee joints = 90° bent members to prevent axial P wave propagation.
3. Load with lumped mass near the middle of truss members to reflect impulse energy.
4. Use a plastic sleeve on the pins in the joints. Acoustic mismatch reflects energy.
5. Mix your materials, bamboo, wood or aluminium all sound different to steel.
6. Use a tensegrity structure. http://en.wikipedia.org/wiki/Tensegrity
Likes 1 person
Thanks guys for that..I am now looking for any online app for testing/simulating my truss-bridge. Is there any free app with decent features?
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
