mrmojorising
- 9
Say you have a conductor (a single straight wire) which goes from left to right across your computer screen and moves up and down in periodic motion in a constant magnetic field that goes into your computer screen (see diagram below).
(note: you can ignore the computer screen, and you can ignore the Earth's magnetic field. i am just trying to set up a situation where a wire moves orthogonally to a constant magnetic field and am using the computer screen, etc. for reference to make the situation more explicit)
The charges in the wire will be subject to a force from the formula F=qvxB, and this force will create periodic motion of the charges since the wires motion is period. This motion will cause a current since the force will cause the charges to move and by definition current is dq/dt.
My questions:
Will a typically current meter/anemometer connected to both ends of the wire with leads record an rms value for the current? (i think no)
Will a touch-less current clamp anemometer (http://en.wikipedia.org/wiki/Current_clamp) placed around the wire record an rms value for the current? (my guess is yes)
Say you connect a stationary conductor to the moving conductor described above (a stationary single wire connected to the moving single wire by a piece of flexible conductor). Does that electric field created by the charges in periodic motion on the moving conductor prorogate to the stationary conductor? If the electric field does propagate to the stationary single wire does it induce periodic motion of the charges and thus an AC current in the stationary single wire?
more explicitly:
---------- <----- wire
| <------- direction of wires motion (periodically up and down)
v
x x x x x x <----- direction of constant magnetic field into which wire is placed (into computer screen)
My questions:
more explicitly:
v
