Wing Drilling: Experiments & Results Explained
  • Thread starter Thread starter wolram
    Holes Wings
The discussion revolves around the concept of drilling tiny holes in wings to manipulate the boundary layer, with references to various experimental approaches and their implications for aerodynamics. Participants explore the effectiveness of different methods, including laminar flow control, vortex generators, and the use of blown flaps, while also sharing anecdotal experiences and research findings related to airflow management in aviation and automotive contexts.
  • Experimental/applied
  • Some participants mention experiments involving drilled wings aimed at breaking up the boundary layer to improve lift and control.
  • There is a suggestion that laminar-flow skin technology involves pumping air through holes to prevent boundary layer formation.
  • One participant shares insights from a drag racer who believes that roughening intake manifolds can enhance airflow by creating micro-turbulence.
  • Another participant discusses the use of blown flaps, which utilize compressed air to energize the boundary layer and improve lift at low speeds.
  • Some participants propose that vortex generators are a simpler method for managing boundary layers without extensive modifications to wings.
  • There is mention of a university project developing wings with numerous tiny holes to control flight without traditional control surfaces, indicating ongoing experimental work in this area.
  • Concerns are raised about the practicality of drilled holes, with one participant noting that they can clog easily, undermining their effectiveness.
  • References to various research articles and presentations are shared to support claims and provide additional context on the topic.
Participants express a range of views on the effectiveness and practicality of different methods for managing boundary layers, indicating that multiple competing perspectives exist. The discussion remains unresolved regarding the best approach to take.
Some claims depend on specific conditions or assumptions about airflow dynamics, and the effectiveness of various methods may vary based on application and design constraints. There are unresolved questions about the long-term viability of drilled holes in wings and their susceptibility to clogging.
wolram
Dearly Missed
I am sure i read about experiments with wings drilled with many tiny holes, the idea i think was to break up the boundary layer, did any thing come of out of these experiments?
I suspect that you're thinking of 'laminar-flow skin'. If so, air is pumped out through the holes in order to prevent a boundary layer from forming. That's all that I've got; Fred can probably help you out a lot more.
I don't know about that, Woolie, but I have a friend who has been the National champion in his drag-racing class (he runs a classic 340 Duster) and is always competitive. He claims that if you polish intake manifolds, it supports laminar boundary-flow and that causes drag. He has his intake manifolds roughened to some arcane standards that he and his head-work specialist know, and he claims that the micro-turbulence in the air/manifold boundary acts like "little ball-bearings" as he puts it, to allow the bulk of the intake air to get to the cylinders with as little drag as possible. It makes sense, because if you can get the air rolling in little tiny pockets and the air is rolling to counter to the bulk air flow just at the boundary, and is rolling IN the direction of the bulk air flow just a little bit away from the air-manifold boundary, the bulk of the air would get a little boost from the rotating air cells near the boundary. He races in a class that is very restrictive about the modifications that are allowed to the car, so every little secret helps.
It actually goes both ways depending on how you are looking to do it. I have to run, but here's a link to the opposite:
In a conventional blown flap a small amount of the compressed air produced by the jet engine is "bled" off of the compressor stage and piped to channels running along the rear of the wing. There it is forced through slots in the wing flaps of the aircraft when the flaps reach certain angles. This air follows the flap profile, aimed downward to provide more lift. The bleed air prevents the boundary layer (slow-moving air that accumulates on the airframe surface) on the upper surface of the flap from stagnating, further improving lift. At low speeds the amount of air being delivered by this system can be a significant fraction of the overall airflow, generating as much lift as if the plane were traveling at much higher speeds.
http://en.wikipedia.org/wiki/Blown_flap
I found at my expense in time that a sand blasted cylinder head gave improved pick up over one i had spent hours polishing, then found out it was shape that really mattered
and the surface is best left (cast).
russ_watters said:
It actually goes both ways depending on how you are looking to do it. I have to run, but here's a link to the opposite: http://en.wikipedia.org/wiki/Blown_flap
Is this like a venturi effect?
It's not quite the same thing (but sort of close) and I don't have a source at the moment (I needed to use my neuron today and now it's over at the National Aviary resting), but the US Navy was looking at doing something like this for torpedoes.
These methods seem like a lot of work, for breaking up the boundary layer. The use of vortex generators do this with little cost and no mods to the wing exept mounting them.
Wolram,
I found this article maybe you have already seen it.
http://www.hero.ac.uk/uk/business/archives/2002/perforated_wings_take_fli1354.cfm
All these methods don't really break up the BL but rather energize it so it will stay attached longer. This can be done by using VG's like frogman says but for high curvature area's this may not seem to be enough so holes are common think of the triple slotted flaps on the trailing edge of a 747.
VGs always seem like the first line of defense for separation prevention. However, I believe Wolly is referring to vacuum assisted BL control that NASA was working on. Honestly, I haven't heard anything lately. I'll have to see if I can dig up any results or reports.
An aero professor and some grad students at my university were developing a wing that instead of using control surfaces used tons of tiny holes on the top and bottom of the wing of the aircraft. Using an internal pump and ducting to the holes, they directly changed the pressure above/below the wing to control the aircraft's flight, taking over control which would normally be accomplished through control surfaces on the wing.
From what I understand, they were able to create a working testbed out of an R/C airplane. It is a very interesting sounding technology.
Here is a link to Powerpoint presentation regarding an experimental application to tilt-rotor aircraft (e.g. Osprey).
http://www.ame.arizona.edu/research/aerolab/media/MAFC_XV-15_Media_and_VIP_Day_Briefing_Final.ppt
Other links for similar experimental development:
http://www.ame.arizona.edu/research/aerolab/research/experimental.html
http://www.ame.arizona.edu/research/aerolab/research/applications.html
We are doing similar things at my university as well. However, our flow control is done on missiles. Aside from holes (I don't believe ours are pumped though), they have a lot of other methods for flow control which are pretty neat.
Please do! I'm totally unfamiliar with this, and it sounds fascinating.
The holes in the wings clogged too easily to make the system worthwhile.
Hi pantaz, did you work with this idea, if so do you have any data.
Thank you pantaz.
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 31 ·
13K
  • · Replies 17 ·
