How Do I Understand and Improve Wireless Antenna Strength?
Understanding antenna strength in wireless cards involves examining the receiver sensitivity, measured in dBm, which indicates how well a card can detect signals. A more negative dBm value signifies greater sensitivity; for instance, -70 dBm is significantly weaker than -20 dBm. When selecting a wireless card, it is advisable to look for one with a sensitivity that is at least 3-6 dB better than another to ensure noticeable performance improvements. However, receiver sensitivity is just one factor; other elements such as antenna directionality and analog processing losses also affect performance. WiFi standards vary in speed, and as signal quality diminishes, the connection may still function but at reduced speeds. Generally, most consumer wireless products exhibit similar range capabilities, and issues with connectivity are often better resolved by adjusting the access point rather than switching to a different wireless card.
buddyholly9999
Ok. I'm currently trying to understand antenna strength in the wireless cards you find for your computer. Let's say that I have a wireless http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=706706&Sku=D700-2286" with a certain "receiver sensitivity". How exactly do I read this?
I'm trying to find an explanation or perhaps a reference to something that can explain this to me. So if I wanted to find another card, perhaps with a stronger antenna...or one that was better equipped to receive signals better what exactly would I be looking for?
Computer science news on Phys.org
"OFDM" refers to a specific kind of digital modulation, orthogonal frequency-division multiplexing. The available spectrum is broken up into a large number of small, adjacent channels. Each channel is then used to carry a single BPSK, PAM, or QAM signal.
PER refers to packed encoding rules, which is essentially a "data compression strategy" used to reduce the number of symbols needed to transmit a given piece of information.
The sensitivity itself is given in dBm, or decibels with respect to one milliwatt.
1 dBm is equivalent to one milliwatt.
-10 dBm is equivalent to 0.1 milliwatt.
-20 dBm is equivalent to 0.01 milliwatt.
-70 dBm is equivalent to 0.0000001 milliwatt, or about one tenth of one billionth of a watt.
The more negative the receiver's sensitity spec, in dBm, the more sensitive is the receiver.
- Warren
So I wanted let's say a PCI card or USB. I could just look at the receiver sensitivity and find one in which the dBm is more negative and that card would essentially pick up my wireless network...let's on the other end of my house better than the PCMCIA card I gave a link to above?
There are many other factors. I believe the specified value is actually the receiver sensitivity, and does not include issues like antenna directionality, upstream analog processing losses, etc. The digital receiver itself is an integrated circuit at the end of a long analog signal path.
I personally would not make a determination of which card to get solely by its receiver sensitivity spec, unless one card's sensitivity is more than, say, 3-6 dB better than an another's.
Keep in mind that WiFi standards include a wide range of speeds. As the signal degrades in quality, smaller signal constellations are used -- you'll still receive network service, but it'll be lower speed.
I'd suspect that most consumer wireless products are relatively similar in range performance. If you're having trouble with one brand of card, you're more likely to solve the problem by moving the access point than you are by buying a different wireless card.
- Warren
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
In my discussions elsewhere, I've noticed a lot of disagreement regarding AI. A question that comes up is, "Is AI hype?" Unfortunately, when this question is asked, the one asking, as far as I can tell, may mean one of three things which can lead to lots of confusion. I'll list them out now for clarity. 1. Can AI do everything a human can do and how close are we to that? 2. Are corporations and governments using the promise of AI to gain more power for themselves? 3. Are AI and transhumans...
