Word problem polynomial f(x) help
The discussion centers on solving a polynomial problem related to the volume of a sandcastle box, originally measuring 36cm by 48cm by 60cm. Participants work through the polynomial function p(x) = (36-x)(48-x)(60-x) to find the new dimensions after a reduction. The volume of the smaller box is determined to be 62,208 cm³, which is 3/5 of the original volume. To find how much was taken off each dimension, the equation (36-x)(48-x)(60-x) = 62,208 is suggested, with some participants noting that a graphical solution may be necessary. The approximate reduction needed for each dimension is suggested to be around 9.28 cm.
Nelo
2 People build a sandcastle of 36cm by 48cm by 60cm. Later they learn that the box will be smaller; a certain amount will be taken off each of the length width and height
a) write a p(x)
> (36-x) (48-x) (60-x) , also x intercepts if (-x+36) = -(x-36) etc
b) graph (already did)
c) the amount of sand in the boc will be 3/5 of the amount in the design) , so i multiplied the l*w*h and then multiplied it by 3/5 and got the answer of 103,680 *3/5 = 62,208
d) How much was taken off each dimension? ( HOW DO I SOLVE THIS?) anyone? steps please
any1?
Nelo said:
any1?
Before the answer we'd need a question.
a) write a p(x)
What do you mean, "write a p(x)" - A function that represents what?
Please give us the exact problem statement.
Looks like you'll need to take p(x) and set it equal to 62,208:
(36 - x)(48 - x)(60 - x) = 62,208
However, unless you're allowed to solve it graphically using a graphing calculator, I'm not sure you can solve it algebraically (unless you know the cubic formula).
Um, Idk, the answer booklet says "approxmiately 9.28" , but yes I am on d) and that is the function...
your method did not work
If each dimension is reduced by 7.15 you get very close to the desired smaller volume.
Hmm, then either the answer booklet has a typo or you copied the problem wrong. I got the same answer that NascentOxygen got.
9K
