Work and Potential Energy Problem
The problem involves calculating the weight of a load raised by a 140 Watt motor with 70% efficiency over a height of 5 meters in 5 seconds. The motor's effective output is determined to be 98 Watts, leading to a potential energy of 490 Joules. Using the formula PE = mgH, the calculated mass comes out to 10 kilograms. However, the expected answer is 110 kilograms, suggesting a discrepancy. The discussion concludes with a recommendation to consult the professor for clarification on the solution.
bengaltiger14
A 140 Watt motor (70% efficient) is available to raise a load 5 meters into the air. If the task takes 5 seconds to complete, how heavy was the load in kilograms?
I first determine the motot output: 140W * 70% == 98 Watts
I then multiply 98 Watts by 5 seconds to get PE = 490Joules
Now, setting 490Joules = mgH and solving for m, I get 10 kilograms
The answer is supposed to be 110kg according to my professor but I cannot get to that number. What am I doing wrong?
Thanks
Your answer looks good to me. I don't think you did anything wrong. (Ask your professor to show her solution.)
