How Is Work Calculated Along a Semicircle in Vector Calculus?
  • Thread starter Thread starter HeisenbergW
    Work Work done
HeisenbergW
Find the work done along the semicircle (x-1)2+y2=1 from the point (0,0,0) to (2,0,0)
When F=r3cos2φsinφ\hat{r} + r3*cosφ*cos(2φ) \hat{φ}
Work
W=∫F*dr
where dr=dr= dr\hat{r} + rsinφdφ\hat{φ}
I convert the equation of the line (x-1)2+y2=1 to cylindrical coordinates.
Where x=rsinφ
and y=rcosφ
so (x-1)2+y2=1
eventually becomes r=2cosφ
now i plug in this r value into the force vector given, which gives me F=8cos5φsinφ\hat{r} + 8*cos4φ*cos(2φ) \hat{φ}
W=∫F*dr
So now i dot product this with the dr, which is now dr= dr\hat{r} + 2cosφ
sinφdφ\hat{φ} due to the r value I found.
The dot product comes out to be
∫8cos5φsinφdr + 16*cos5φ*cos(2φ)sinφdφ
and because r=2cosφ, dr=-2sinφ dφ
so this is once again plugged into the integral of the dot product, creating
∫-16cos5φsin2φdφ + 16*cos5φ*cos(2φ)sinφdφ
where I integrate from pi/2 to 0, since it ends at x=2 and y=0, but begins at x=0 and y=0
This gives me -4/35, which does not seem to be a correct answer
Any mistakes?
Any help is appreciated
Thank You in advance
The equation is not correct.The second terms has to be rdφ\hat{φ}.
And make the vector \vec{dr} different from dr, change of the coordinate r.
ehild
For d\vec{r} I actually left out the second term, which is the elevation angle, since it is constant. I guess I should have clarified that I am using this in spherical coordinates, but I did produce a typo It should be
dr\hat{r}+rsinθd\varphi\hat{\varphi}.
Which of course just simplifies to
dr\hat{r}+rd\varphi\hat{\varphi}
because θ constantly equals pi/2
So you can ignore the lone sin at the end of the force vector, since it goes to one. Yet it still goes to a negative value unfortunately.
The integration path is not clear: You can reach from (0.0,0) to (2,0,0) along the upper semicircle or the bottom one, yielding integrals of opposite signs.
ehild
My apologies, we must go along the circle where y>0
The integral is negative then.
ehild
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
