Work done by force on an angle
In summary, a 3kg box is being pushed up a frictionless ramp with a constant force of 82N at an angle of 53 degrees. The work done by that force when the box has moved through a vertical distance of 0.15m can be calculated using the equation W = m*g*distance. This takes into account the change in potential energy caused by the lifting force, but not the potential kinetic energy due to a possible change in velocity.
PhysicsPete2564
In the figure below (image attached) a constant force of 82N is applied to a 3kg box at an angle of 53 degrees causing the box to move up a frictionless ramp. How much is work is done by that force (Fa) when the box has moved through a vertical distance of .15m?
Work = Force X distance
I thought this would be a simple problem. Work equals force X distance so I thought you would just multiply the force and distance vectors. Multiplying the vectors means using the dot product. So initially I just did:
W = (82N)*(.15m)*(Cos(53)). This equals 7.40 which is not the correct answer.
I found a problem similar to this on the web and apparently the way to do this problem is W = m*g*distance. This produces the right answer for the problem (4.41) but I don't understand the logic behind that equation. I thought since the force and distance are NOT equal in direction you need to multiply vectors. What am I missing here?
Thank you,
Allen
If you walk up one stair, and you know your weight and the height of the stair, you can work out the work done in achieving this. If someone lifted you up and put you down one step higher, would that change the work done?
That makes sense I think, but I feel I'm missing something still. So in the stairs example that force that lifted me was basically overcoming the gravitational potential energy. That gravitational potential energy wouldn't change. But if a force lifted me up wouldn't that in turn change my velocity from 0 to some number? So if my velocity changed shouldn't there be kinetic energy? And then the KE in the stairs example would be force done by someone lifting me up minus the GPE.
I think this is where my thinking may be wrong: In your staris example the force done by someone lifting me would some amount. Then if you subtract GPE from that amount your left with KE. So soundless the force of someone lifting me (or pushing a block up a hill) be more than the GPE because it is changing the velocity?
The lifting force was overcoming gravity.
Sure it would. If you lift something, its potential energy increases.
Not necessarily, if the force doing the lifting was equal in magnitude to the frictional force opposing the motion. If you push a heavy box across a floor at a constant speed, the friction force counterbalances the force you're applying, so the net force is zero.
It does seem as if the answer only includes the change in PE. The block could be accelerating. I take it the problem doesn't say anything about constant velocity?
What is work done by force on an angle?
Work done by force on an angle is a measure of the amount of energy transferred by a force to an object at a certain angle. It takes into account both the magnitude of the force and the displacement of the object in the direction of the force.
How is work done by force on an angle calculated?
Work done by force on an angle is calculated by multiplying the magnitude of the force by the displacement of the object in the direction of the force, and then multiplying that by the cosine of the angle between the force and the displacement. This can be represented by the equation W = Fdcosθ, where W is work, F is force, d is displacement, and θ is the angle.
What is the unit of measurement for work done by force on an angle?
The unit of measurement for work done by force on an angle is joules (J). This is the same unit used to measure energy.
How does the angle affect the amount of work done by force?
The angle between the force and the displacement affects the amount of work done by force. When the force and displacement are parallel (θ = 0°), the work done is at its maximum. As the angle increases, the amount of work done decreases. When the force and displacement are perpendicular (θ = 90°), no work is done.
What are some real-world examples of work done by force on an angle?
One example of work done by force on an angle is pushing a lawn mower up a hill. The force of pushing is at an angle to the displacement of the lawn mower, resulting in work being done. Another example is lifting a book from the ground to a shelf. The force of lifting is at an angle to the vertical displacement, resulting in work being done.
