Work Done by Gravity on 265kg Load: 6.24x10^4 J
The discussion centers on calculating the work done by gravity on a 265-kg load lifted 24.0 m with an acceleration of 0.190 g. The initial calculation of the force of gravity was correct, yielding 2.6 x 10^3 N, and the work done was calculated as 6.24 x 10^4 J using the angle of 0°. However, the correct answer should reflect the opposite sign due to the angle being 180°, as gravity acts downward while the displacement is upward. This highlights the importance of considering the direction of forces in work calculations. Understanding the relationship between force direction and displacement is crucial for accurate physics problem-solving.
PeachBanana
A 265-kg load is lifted 24.0 m vertically with an acceleration =0.190 g by a single cable.
Determine the work done by gravity on the load.
Force of Gravity = mg
W = F * d * cos (theta)
I think I know why I did this incorrectly but I want to make sure.
First attempt: Force gravity = (265 kg)(9.8 m/s^2) = 2.6 * 10^3 N.
W = (2.6 x 10^3 N) (24.0 m) * cos (0°)
W = 6.24 x 10^4 J.
The correct answer is the same magnitude but the opposite sign. Is that because the angle should have been 180° because gravity always points down? The displacement is up so therefore the angle between the net force and the displacement would have been 180°, not 0°?
W = 6.24 x 10^4 J.
That looks fine. What's your question?
I did it incorrectly the first time but I wanted to make sure I knew why it was wrong.
Yes, if your displacement is in the positive direction, then in this case gravity must be in the opposite direction (180 degrees from positive direction).
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
