Work done by motor pulling up elevator
The problem involves a freight elevator with a specific mass that needs to travel upward over a distance within a set time frame. The challenge is to determine the average power required from the motor, taking into account the counterweight's effect on the system.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants discuss the use of kinematic equations and the implications of constant velocity on acceleration. Questions arise regarding the work done to raise the elevator and the role of the counterweight in the calculations.
Some participants have offered guidance on considering average versus instantaneous power and the importance of calculating the work done. There is an ongoing exploration of the energy changes involved in the system, particularly regarding potential energy and the counterweight's influence.
Participants express uncertainty about the calculations and the relationship between work done and time. There is a mention of homework constraints that may affect the approach to the problem.
JUSTaROCK
A fully loaded freight elevator has a cab with a total mass of 1490 kg, which is required to travel upward 58
m in 2.1 minutes, starting and ending at rest. The elevator's counterweight has a mass of only 985 kg, so the
elevator motor must help. What average power is required of the force the motor exerts on the cab via the cable?
F=ma
W=F * D D= displacement (distance traveled)
P = W/t P= power, t = time
v=u + at u = initial velocity, v = final velocity
v^2 = u^2 +2aD
D= ut + 1/2(a)t^2
I have tried to solve for a by using the formula D= ut + 1/2(a)t^2 then taking that a and multiplying it with the mass then multiplying that by distance and then dividing by the time needed to be done but i can't get it right and i feel like i should do something with the counterweight but i don't know what any thing will help thank you
I don't recommend using kinematics on this one. I think you're supposed to assume that the elevator travels up slowly, at a constant velocity. (Constant velocity corresponds to 0 acceleration :wink: .)
How much work is required to raise the elevator all the way up? All that work is done in how much time? So how much work is done per unit time? What does that mean? :-p
sorry don't follow you on the work done per unit time but i do understand the 0 acceleration
Are you considering average power or instantaneous power in your calculation?
How much work is actually being done? How is the counterweight affecting the system?
What is the potential energy difference between the situations where the elevator is at the top and bottom (considering the counterweight too, which is helping the situation)? How much energy per second would be required to get it all that change in energy done in 2.1 minutes?
i got it thank you
  • · Replies 31 ·
