How Much Work Is Needed to Stretch a Spring from 12 cm to 16 cm?
In summary, the conversation discusses the calculation of work done to change the length of a spring with a relaxed length of 7 cm and a stiffness of 50 N/m from 12 cm to 16 cm. The correct formula to use is 1/2*k*s^2, where s is the stretch of the spring in meters. The calculation provided in the attempt at a solution is incorrect as it does not take into account the difference in stretch between the two lengths. The correct answer is 0.14.
magma_saber
73
A spring has a relaxed length of 7 cm and a stiffness of 50 N/m. How much work must you do to change its length from 12 cm to 16 cm?
1/2*kss2
1/2*50*(.16-.12)2 = 0.04
It shows the solution to be 0.14. It says the change in the energy of the spring is its change in potential energy, so the change in (1/2)kss2. Be sure to use the stretch s, not the length, and use meters, not centimeters.
Looks like an algebra error and a misunderstanding of stretch.
Length 12 is a stretch of 12 - 7 = 5. Length 16 is a stretch of 16 - 7 = 9.
.5k(.09)^2 - .5k(.05)^2 is not equal to .5k(.09-.05)^2.
I would like to commend your approach to solving this problem. You have correctly used the equation for the potential energy of a spring, which is (1/2)kss^2. However, there are a few things that need to be addressed.
Firstly, in your attempt, you have used the change in length (0.04 m) instead of the stretch (0.04 m) in the equation. This will lead to an incorrect answer. The correct equation to use in this case would be (1/2)k(s2-s1)^2, where s1 is the initial stretch (0.05 m) and s2 is the final stretch (0.09 m).
Secondly, it is important to use consistent units in your calculations. In this case, the stiffness of the spring is given in N/m, so the stretch should also be in meters. This means that the initial stretch of 7 cm should be converted to meters (0.07 m) before using it in the equation.
Taking these into consideration, the correct calculation would be:
(1/2)(50 N/m)((0.09 m-0.07 m)^2) = 0.04 J
Thus, the work done by the spring in changing its length from 12 cm to 16 cm is 0.04 J. This means that you would need to apply 0.04 J of external force to stretch the spring from 12 cm to 16 cm.
Related to How Much Work Is Needed to Stretch a Spring from 12 cm to 16 cm?
What is work done by a spring?
Work done by a spring is the amount of energy transferred to or from an object due to the deformation of the spring. It is typically measured in joules (J).
How is work done by a spring calculated?
The work done by a spring can be calculated using the equation W = 0.5kx^2, where W is the work done, k is the spring constant, and x is the displacement of the spring from its equilibrium position.
What does a work done value of 0.04 J indicate?
A work done value of 0.04 J indicates that 0.04 joules of energy have been transferred to or from an object due to the deformation of the spring. It is a relatively small amount of work compared to other forms of energy.
Can work done by a spring be negative?
Yes, work done by a spring can be negative if the displacement of the spring is in the opposite direction of the force applied. This indicates that energy is being transferred from the object to the spring, rather than the other way around.
What factors affect the amount of work done by a spring?
The amount of work done by a spring is affected by the spring constant, the displacement of the spring, and the direction of the force applied to the spring. The stiffer the spring (higher spring constant), the more work is done for the same displacement. The greater the displacement and the force in the same direction, the more work is done.
