Work Done in Circle - Why Not Zero? (Calc 3)
The discussion centers on understanding why the work done by the force field F(x,y) = (x+2y^2)j around a circular path is not zero, despite the object returning to its starting point. It highlights that work is zero only in conservative force fields, where the net displacement is zero, but the given force field is not conservative. The conversation clarifies that while zero work over any closed loop indicates a conservative field, zero work over a single loop does not guarantee conservativeness. The distinction between conservative and non-conservative fields is emphasized, particularly in relation to the work done in different scenarios. This understanding is crucial for correctly applying concepts from calculus and physics.
Weather Freak
Find the work done by the force field F(x,y) = (x+2y^2)j as an object moves once counterclockwise about the circle (x-2^2+y^2=1 by first evaluating the integral directly then use Green's Theorem and evaluate the double integral.
W = F*D*cos(theta)
My problem is not in getting the answer. I haven't gotten the final answer yet, but that's not the issue at hand.
My Calc teacher told me that it is NOT zero, and I am wondering why. If you move around in a circle, there is no displacement, so therefore, work should be equal to zero. So what is it that makes this case different from everything I did in Physics class?
If you move around in a circle through a force field that is a gradient of a scalar function, the work done by the force field is zero. Gravity is a conservative force for this reason--gravity is the gradient of gravitational potential. But if the force field is not the gradient of a function, the work done can be nonzero.
The force fields in physics (gravitational & coulombian) are conservatives. This means that they have the special caracteristic that if the net displacement is 0, then so is the total work. But not all vector fields have this property.
W = F*D*cos(theta)
Surely you were not taught that the work done in moving away from and then back to an initial point is always 0? That is true only for a conservative force field. This field is not conservative.
Okay, I think I get it now, thanks! One more thing though... if the work ends up being zero, does that necessarily imply that the vector field is conservative, or is it only true the other way around?
If the work is 0 over ANY closed loop, then the field is conservative. But if it is 0 over one particular loop, it does not mean that it is conservative. It could be non-zero around some other loop.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
