Work done to pull the entire chain
5 replies · 4K views · last reply
deep838
A chain of mass 4Kg and length 2m is lying on a table, such that 60 cm of one end is hanging from one edge off the table. Find the work done to pull the entire chain on the table.
(anything that'll work i suppose)
I thought that the work done to do this is simply the work done against gravity to lift the hanging mass.
The mass per unit length of the chain is λ=m/l=2Kg/m
So the mass of the hanging portion is λ*60cm=2*0.6Kg=1.2Kg
So the work done to lift it 0.6m up is 1.2*9.8*0.6J=7.056J
But the given answer is 3.6J.
What am I doing wrong?
You assumed that the entire mass of the portion of the chain that needs to be lifted is 0.6 m below that table. But that is not correct. Most of the portion is above that. And those parts need less work. How could you take this into account?
I don't get that! The mass that's on the table is on the table! So shouldn't I lift only the part that's hanging?
The part that is hanging is contiguous. Only its end is 0.6 m below the table. The other bits of the hanging part are still below the table, but HIGHER than 0.6 m.
Oh yeah! of course! so if I assume lifting the centre of mass of the hanging portions, then I lift 1.2Kg by 0.3m! the answer then comes! thanks.
