Work Energy Problem Homework: Find v'B, W & in eV
To find the translational speed v'B of the particle at point B, the energy method is applied, yielding a result of v'B = 11.38 m/sec. The work done by the electric force can be determined using the relationship between potential energy and work, specifically that the change in potential energy equals the negative of the work done. The potential difference of 32.5 V between points A and B is crucial for calculating this change in potential energy. The discussion emphasizes understanding the connection between electric potential and work to solve the problem effectively.
Mirth
A particle has a mass of m = 1.8*10^-5 kg and a charge of q = +3.25*10^-5 C. It is released from point A with an initial speed of v'A (v of A) = 3.5 m/sec and accelerates until it reaches point B. The charged particle moves along a straight line and does not rotate. The force on the particle is just the electric force. The potential difference between points A and B is V'A-V'B= 32.5 V.
a) Use ethe energy method to find the translational speed v'B of the particle at point B.
b) Find the work done by the electric force in Joules.
c) Convert the answer in part B into eV.
Not sure.
So after about an hour of hard work, I'm pretty sure that the answer is v'B = 11.38 m/sec.
I have NO clue what formula I would use to find Work for question b. The closest thing I can find in my book for this chapter is EPE'B - EPE'A = -W'AB. And from other chapter, W = F*d.
If anyone could help me get on track, I'd greatttly appreciate it.
Yes exactly. The change in potential energy of the particle is equal to the negative of the work done on it between points A and B. So, what is the change in the particle's potential energy? Hint: how is it related to the potential difference between those two points?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
