Calculating the Length of a Driveway Using the Work-Kinetic Energy Theorem
  • Thread starter Thread starter BadCo55
    Energy Theorem
To calculate the length of the driveway, the work-kinetic energy theorem is applied, where the net work done on the car equals its change in kinetic energy. The car's initial kinetic energy is zero since it starts from rest, and the final kinetic energy is determined using its mass and speed at the bottom of the driveway. The work done against friction is calculated using the friction force and the distance traveled, which is negative due to the opposing direction of friction. The equation Wnet = KE leads to solving for the length of the driveway. A complete solution requires showing all calculations to clarify the process.
BadCo55
A 2.1x103 kg car starts from rest at the top of a driveway that is cooped at an angle of 20.0° with the horizontal. An average friction force of 4.0 x 103 N impedes the car's motion so that the car's speed at the bottom of the driveway is 3.8 m/s. What is the length of the driveway.
Wnet = KE
In other words: Work = m1v1/2 - m2v2/2
Work = force x distance
Please give me some work along with the answer so I can understand how to complete the problem.
Hi BadCo55! Welcome to PF! :wink:
Show us what you've tried and where you're stuck, and then we'll know how to help! :smile:
That's the thing, I really don't know how to start...
start with the work-energy theorem
Would it be d = -0.2625 ? Since it's frictional force I put -4.0x10^3
(just got up :zzz:)
please show your calculations :smile:
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
