Work problem -- raising a chain and load
The problem involves calculating the work done by a winch in raising a 40-foot chain weighing 4 pounds per foot, along with a 600-pound load, from a height of 40 feet. The integral used for the calculation is ∫ from 0 to 40 of (600 + 4(40-y)) dy, resulting in a total work of 27,200 ft-lbs. The solution is confirmed by considering the change in gravitational potential energy for both the chain and the load. The approach and calculations appear to be correct. The discussion concludes with confidence in the accuracy of the answer.
Mr Davis 97
Consider a 40-foot chain that weighs 4 pounds per foot hanging from a winch 40 feet above ground level. Find the work done by the winch in winding up the entire chain with a 600-pound load attached to it.
##\displaystyle \int_{0}^{40} 600 + 4(40-y) ~dy = 27200 ## ft-lbs
Is this the correct answer?
Likes scottdave
It looks correct. I get the same answer if I consider the center of mass of the load and chain and find the change in gravitational potential energy of the objects.
Likes scottdave
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
